jim_hoyland |
Get that VIN ? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,805 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California ![]() ![]() |
I have my original TS switch on the bench. The 6 tabs with incoming wires all show continuity with the respective pins for the parking lights and turn signals.
But when I set the handle to left or right and test the pins for continuity for the parking lights nothing. When looking at the switch, there are three tabs which I’m looking at and wonder whether the switch can be opened for further inspection. Here’s pics of the tabs; 2 on the bottom, one on the top. Attached image(s) ![]() ![]() ![]() |
barefoot |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,408 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States ![]() ![]() |
I had to clean the sliding contacts that get used for the turn signals. i had no continuity until i cleaned these sliding contacts.
Barefoot |
jim_hoyland |
I had to clean the sliding contacts that get used for the turn signals. i had no continuity until i cleaned these sliding contacts. Barefoot @barefoot That’s encouraging. How did you do it ? I’m not sure I’ve been able to see the sliding contacts. |
barefoot |
I had to clean the sliding contacts that get used for the turn signals. i had no continuity until i cleaned these sliding contacts. Barefoot @barefoot That’s encouraging. How did you do it ? I’m not sure I’ve been able to see the sliding contacts. used a mild acid, then water flush. |
jim_hoyland |
Thanks, gonna give that a try; what acid wash should I use ?
BillC |
Senior Member ![]() ![]() ![]() Group: Members Posts: 671 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region ![]() ![]() |
I would suggest maybe trying contact cleaner spray first, before soaking it in any acid.
jim_hoyland |
I would suggest maybe trying contact cleaner spray first, before soaking it in any acid. Good call. Thanks (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 1st July 2025 - 05:56 PM |
