after I replaced the dimmer switch the question I have is.
once installed should it have a position to lock in the brights then back to low?
its been awhile since I drove a stock 914 but I thought I remember it moved and stayed in 2 different positions until you manually changed it. I have yet to install the steering wheel if that makes any difference
