Full Version: Turn signal indicator lights come on with key
GeorgeKopf
I'm wring my 1973 wiring harness and have a bunch of things installed which seem to be working correctly (i.e. headlights (high & low beam), headlight motors, turn signals, running lights, tail lights)
But bootyshake.gif the turn signal indicators are always on!
I've traced the flow of current from the fuse panel (red with white stripe) to the hazard switch, from there (red) to the relay and from there to the turn signal indicators (blue with white stripe).
47 is the relay
31 is the hazard switch
22 is the turn signal lights
26 is the steering column switch
I have two relays and both seem to work fine. When I pull out the hazard switch the indicators and lights all blink. When I set the turn signal that side blinks.
I have two hazard switches and both behave the same way. As soon as I connect the red and red/white wires the turn signal indicators come on.
With the knob pushed in, I have continuity between the red/white (power in) and the red (power out to the relay).
With the knob pulled out, I have continuity between the black/red (power in) and the red (power out to the relay). confused24.gif
More information:
I have cleaned all grounding studs.
I disassembled one of the relays and cleaned it.
If I disconnect all of the wires from the hazard switch except for the red/white and the red, the signal indicators come on and stay on. Doesn't this mean that my relay is bad? It should be getting power so that it can feed the turn signal indicators when the turn signals are set.
It seems that the relay is allowing the input power to the blue/white wires when it shouldn't.
If so, is there a good way to test or repair them?
Thanks in advance for any advice.
George
904svo
jUST A wag check that the brown wire is connect to the gauge case wich is ground
Simplified wiring diagram from Spoke
Take note of how indicators flow to ground through the opposite side turn signal bulbs.
QUOTE(GeorgeKopf @ May 26 2025, 06:25 PM) *
No
There are lots of other ways the wiring could be screwed up and sending power or grounds to the indicator lamps.
rfinegan
ON or blinking?
My problems have allows been a bad flasher /hazard relay
See diode in the flasher circuit. This results in the light on but not blinking till the signals/ flashes are commanded on and then they blink. But previous owner issues my be the cause too
If always blinking look at the parking brake on brake pressure switch on
QUOTE(rfinegan @ May 27 2025, 07:51 AM) *
There is no diode in the flasher circuit. Are you referring to the transistor symbol on the flasher / relay (In Spokes diagram) that indicates the flasher is outputting a 12v on / 0v off pulse ?
rfinegan
My bad, not a diode but replacement did fix my lights on. been dim since I have had my car for 10 years.. Now it works as expected after replacement. Spoke set me on the right path....
GeorgeKopf
@Superhawk996
Thanks for the simplified diagram. I really like that it shows the internals of the hazard relay clearly. My symptoms could be explained if gate L is stuck closed.
@rfinegan
Thank you for your experience. My symptoms exactly match yours. My turn signal indicators are always on.
I'm going to order a new Hazard Flasher relay and hope that fixes it. I'll post the result here.
Thanks to everybody who responded.
George
If you’ve already tried 2 flasher relays, and it hasn’t helped why wouldn’t you do some more troubleshooting with a DMM? The chance of both relays being bad in exactly the same way isn’t great.
Alternatively - why not bench test the relays you already have to either prove or disprove your theory that the relay switch pin K has failed closed. This is easily measured with a DMM. Very straight forward to bench test the flasher relays.
It is always better to troubleshoot than to blindly swap parts hoping for a solution. Cheaper too!
GeorgeKopf
@Superhawk996
I was thinking how I might bench test the relays. Do you know which connector on the unit represents which wire on the diagram?
Also, both relays are probably 50 years old. Do they naturally go bad over time?
Thanks.
George
Spoke
It seems this is your only issue, correct? There's definitely some wiring issue still. Both indicators should connect to their respective turnsignal at the hazard switch. The other sides of the indicators are tied together and connect to K/C/C2 pin on the flasher. Check these connections by ohming out from the indicators to K/C/C2 pin.
QUOTE
If the turnsignals flash with hazard or L and R turnsignals, then the flasher relay is good.
Look at the schematic in post 3. Notice the indicators should be connected to each turnsignal and a common connection going back to the flasher relay.
One test to do is to remove the flasher relay and see if the indicators come on with the key. w/o the flasher relay you should have no turnsignals or indicators lit up.
QUOTE(GeorgeKopf @ May 28 2025, 10:46 AM) *
Germans are very good about putting terminal numbers on parts; either on housing or molded in by the terminals themselves
Relays are pretty robust devices - would be somewhat unusual to have two that are failed the same way but technically not impossible.
If your theory were true you could measure relay terminals with DMM and see if you have continuity between terminals “49” and “k” per schematic in post 3
Terminal k that is on schematic may show up on flasher relay as “c”
Likewise - follow Spoke’s advice as quick method as another valid way to help troubleshoot if the problem is coming from
The flasher relay.
GeorgeKopf
@Spoke
If I remove the flasher relay, the indicators do not come on with the key.
With the flasher relay installed, I get power on the blue/white wire to both indicators.
Also, disconnecting the turn signal switch didn't make any difference.
Thanks.
George
rfinegan
I did use a LED ready hazard flasher, so when I update to LED there will be no surprises.. Mine was a no mode flasher. See Spoke treads for details
IM using stand bulbs and LED IP bulbs at this time
-Robert
GeorgeKopf
@rfinegan
This is very good information. I'm testing with the normal bulbs but will be switching to LED bulbs at some point in the future.
Thank you.
George
Spoke
QUOTE(GeorgeKopf @ May 28 2025, 11:40 AM) *
@Spoke
Thanks.
George
I would expect the indicators to be off with the relay removed. Quite honestly, I'd bypass the K/C/C2 pin on the relay and just ground the common connection of the indicators to the tach ground. I did this on my '71. I'm still using the OEM flasher with all LEDs with no issues.
If you do change to external LEDs the function of K/C/C2 is lost. K/C/C2 is active in the relays as a safety feature to alert the driver of a burned exterior turnsignal bulb. If a bulb is burned out, the relay will not power K/C/C2 during flashing and both indicators will flash together indicating a burned bulb.
An easy workaround which I did on my 914 is to remove the common wire at the indicators and tape them off. Then make a pigtail like shown below. The piggyback connector goes under the tach ground (brown wire) and the 2 female spades go to each indicator. The indicators will flash opposite (L on for right turnsignal; R on for lefts). This is easily fixed by pulling the entire light assembly out and put it in the opposite hole.
Here's spades for the mod. This is the ground piggyback connector. You need 1 of these.
Piggyback Spade
This is for the bulb spades. You'll need 2.
Female Spade
GeorgeKopf
@Spoke You said:
"An easy workaround which I did on my 914 is to remove the common wire at the indicators and tape them off. Then make a pigtail like shown below. The piggyback connector goes under the tach ground (brown wire) and the 2 female spades go to each indicator."
This should be an easy test since my dash is off, and all the gauge wires are exposed.
My flasher relay is only labeled:
....49
49a....C
....31.......(see below)
......................................Relay #1................................Relay #2
Between 31 and 49a:..there is no continuity..................there is no continuity
Between 31 and 49:....resistance is 812 ohms...............there is no continuity
Between 31 and C:.....resistance is 876 ohms..............there is no continuity
Between 49a and 49:..there is no continuity..................there is no continuity
between 49a and C:....there is no continuity..................there is no continuity
Between 49 and C:......resistance is 850 ohms...............resistance is 48 ohms
Lastly, I poked and prodded all the little switches in the mechanisms and some of the above numbers changed significantly.
Thanks.
George
QUOTE(GeorgeKopf @ May 28 2025, 09:15 PM) *
Neither of those flasher relay measurements looks particularly promising. If your measurements are correct, the one with 48 ohms should lead to indicators that glow much brighter than the other.
Good job doing some basic troubleshooting.
I’d agree - short of trying to revive those, or to set up a complete bench test inclusive of incandescent lamp loads I’d order a new one.
Spoke
....49
49a....C
....31.......
This is the same pinout as EP26. EP36 is the same minus the C pin.
Out of the box for EP26 the C pin is open and does nothing. I resell EP26 with the C pin connected to ground for separate L and R. For the single L/R indicator cars, the C pin is connected to 49 via the internal relay when active.
As mentioned before, the K/C2/C pin only has value for all incandescent turnsignals when it operates properly. If one installs LED turnsignals, the pin is worthless. Also over the years, the efficiency of the coil decreases (the large gauge coil in the picture) for K/C/C2 to the point where an indicator may flash once then both flash together.
Unless you really want the alert feature of the K/C2/C pin for burned bulbs, life is simplified by grounding the common connection of the indicators or installing EP26 with K/C2/C pin grounded internally.
GeorgeKopf
@Spoke
Do you open up a stock EP26 and modify it to connect the C pin to ground?
Thanks
George
Spoke
QUOTE(GeorgeKopf @ May 29 2025, 09:47 AM) *
@Spoke
Thanks
George
Yes. I show how to make the mod on my website if you want to do the mod yourself.
GeorgeKopf
QUOTE(Spoke @ May 29 2025, 08:24 AM) *
First of all, you are the man! Thank you for being so generous with your time and expertise.
Second, I'll buy one of your LED relays. Would you prefer that I do it through your website?
Thanks.
George
Spoke
QUOTE(GeorgeKopf @ May 29 2025, 11:52 AM) *
Thanks.
George
Yes. The website is the easiest way.
GeorgeKopf
Before I start a new thread .....
<edit> I just found the answer on 914rubber.com <edit>
https://914rubber-tk.com/doku.php?id=troubl...oglight_problem
You can read the rest for context but the above post has the answer.
While I was waiting for the new flasher relay to arrive, I decided to tackle the fog lights.
With the low beam lights on, when I pull out the fog light switch:
1. High beams switch on
2. High beam indicator comes on
With the high beams on, when I pull out the fog light switch:
1. High beams stay on
2. High beam indicator stays on
I measured the inputs and outputs of the fog light relay:
Pin 30 input power and shows 12 volts
Pin 86 receives power from the fog light switch (gray/red wire)
Here is where it gets weird:
Pin 87 is never energized, switch in or out (white/yellow to the fog lights)
Pin 87a is always energized, switch in or out (dead ended in the socket)
UNTIL I measure Pin 85! Once I put my multi-meter on pin 85 (with the fog light switch pulled out) I now get power (12 volts) on pin 87 confused24.gif (and to the fog lights) and no power on Pin 87a (which is how it should be).
Pin 85 (8.5 volts) connects to the (white/blue) (high beam indicator, connects to the white wire at the fuse panel which feeds the combination relay and the headlights)
Still, pulling out the fog light switch always turns my high beams and the indicator on (instead of off).
27 is the combination relay
53 is the fog light relay
36 is the fog light switch
Power flows from the fog light switch (36) (grey/red) to pin 86 on the relay (53).
From there power flows to pin 85 (white/blue) which turns on the high beam indicator in the tachometer and connects to the white wire feeding the low beams and the combination relay (27)
From the combination relay it sends power to my high beams (yellow wire).
Is this an independent problem or something horrifically wrong with my wiring harness?
Thanks.
George
GeorgeKopf
@Spokes
You can read the rest for context but the answer is in the above link.
I just found and read this post: http://www.914world.com/bbs2/index.php?sho...264737&st=0
Turns out what I'm experiencing is classic with LED headlights.
My wiring harness is a 1973. There are two white/blue wires connected to my #1 fuse. One comes from the fog light relay and the other goes to the high-beam indicator in my tachometer.
Click to view attachment......Click to view attachment
I tried grounding them both. This solves the problem of switching to the high-beams and the relay now provides power to the fog lights. But the high-beam indicator doesn't work anymore. I'm guessing that I need to cut apart the two white/blue wires and only ground the one coming from the fog light relay.
Do I have this right?
Thanks.
George
Spoke
QUOTE(GeorgeKopf @ May 31 2025, 09:09 PM) *
@Spokes
Thanks.
George
@GeorgeKopf
Correct about the high beam indicator. My '71 was not wired with 2 white/blue wires. The white/blue for the fog relay had to be cut from the larger white wire on my 914. I suppose you will need to do the same. Just figure out which white/blue wire is from the foglight relay and cut it off from the other white/blue.
BillC
QUOTE(Spoke @ May 31 2025, 11:05 PM) *
@Spoke s
Thanks.
George
@GeorgeKopf
@Spoke @GeorgeKopf
Thank you both very much for this golden nugget of information. I had been wondering why there were two white/blue wires on the connector when the directions for the fog light fix only indicated one. I hadn't even noticed that my high-beam indicator stopped working.
I cut one wire off the stock plug, soldered on a new plug, and now I have working foglights and a working high-beam indicator light. piratenanner.gif
GeorgeKopf
I installed the new flasher relay this weekend and it solved my problem. My turn signal indicators no longer come on with the key. Everything is working as it should.
Thank you to everybody.
George
Invision Power Board © 2001-2025 Invision Power Services, Inc.
