I'm confused. Can someone clarify if there are two different hose types, length and color. There appears to be a high temp hose (orange - 60mm x 320mm long) and a second hose that is a different color and length (tan 60mm x 420mm) is that right? Seems easy to source the orange "high temp" hose but anyone found a source for the other one?
I have Billy Boat headers with heat exchangers but they are not connected yet. Do we need the hose clamps at the heater (flapper) box that has the cable guide or will any 600mm+ clamp work.
Anyone find a source for cadmium plated clamps or the original slide calms vs. the standard screw type clamps?
Any help appreciated.
Thanks
