Will removing just 1 CM from the top of the shifter lever be noticeable when shifting? In other words, will it be harder to shift and require more effort? I am trying to utilize a custom shift knob which does not cover as much of the shifter shaft as the stock knob, revealing some flaws in the chrome. If I cut off 1 CM from the top of the shaft that bad part will be hidden under the new knob. Thanks.
Ansbacher
