sportlicherFahrer
Apr 6 2015, 06:15 PM
Was checking up on ignition upgrades from Pertronix again and saw that they offer the Ignitor III for our vacuum dizzies now. Supposed to work like a box style ignition without the box(multiple spark, rev limiter). Did a search here and didn't see anything for that model. Anybody used an Ignitor III and have any useful feedback on or off a Porsche? Not looking for opinions on whether or not Pertronix belongs in our cars or not, just on the functionality of the Ignitor III. With that said, I know this may start a
storm.....
76-914
Apr 6 2015, 09:38 PM
colingreene
Apr 7 2015, 11:00 AM
I personally have had problems with the parts they sell.
but it works for others
Java2570
Apr 7 2015, 12:20 PM
I've heard of others using Ignitor II but I'm thinking the Ignitor III won't be compatible with the 914 components. I would try calling Pertronix about it first....I don't see anything on their site saying it
would work with our setups. I'm wrong a lot though so....YMMV!
SKL1
Apr 7 2015, 12:45 PM
Why would this be better than Permatune? I've had a Permatune on my '71 for years with no issues...
SLITS
Apr 7 2015, 12:48 PM
QUOTE(Java2570 @ Apr 7 2015, 11:20 AM)
I didn't see anything about Bosch distributors on their site as well. Limited production for Detroit Iron is all I saw.
sportlicherFahrer
Apr 7 2015, 01:01 PM
Part number 71847v. They run about $130 on Summit and Ebay. Curious to know if they are as easy to set up as the ignitor 1 and 2. I like that the whole set up fits under the cap still, but is multiple spark and also has a rev limiter. If the 3 works well in other applications, it ought to do so on a type 4 engine as well. Good price for that kind of ignition control.
I figure if they are listing the part number it will at least bolt in with a possible mod for the vacuum advance that is needed for the 1 &2.
Java2570
Apr 7 2015, 01:27 PM
I don't see the specific instructions for the 71847v but the other Ignitor III install procedures look very similar to how the Ignitor I & II install. Buy one and try it out and post a review of how it works....
you are elected class guinea pig!!
euro911
May 25 2015, 04:55 PM
I've been running a -II on my 2056 for over 3 years now - but I still carry a spare dizzy w/points just in case
boxsterfan
May 25 2015, 05:23 PM
Opinions on the Pertronix are like reviews on Amazon. Some love/like....some hate. I have Pertronix II. Never bothered me. Either carry spare points, spare Pertonix or have a towing plan with your car insurance. All easily solvable problems.
Dave_Darling
May 25 2015, 08:35 PM
QUOTE(SKL1 @ Apr 7 2015, 11:45 AM)
The Permatune is a Capacitive Discharge Ignition. It makes the spark hotter, and offloads a lot of the current flow from the points. It still uses points, but they pass a low "switching" current rather than the full ignition current.
The Pertronix completely replaces the points, but does not change the way the ignition circuit works. It doesn't make the spark noticeably hotter, but it won't wear like points do.
They're different bits doing different jobs.
--DD
iankarr
May 25 2015, 09:17 PM
I have a P-III on my 65 mustang. Works great. The big diff between the II and the III is that with the III you don't need to install a ring over your dizzy shaft. It senses when the lobe spins around (by the change in magnetic field).
Anyway, my PIII works great. Not sure if it's compatible with the 914. If it is, keep in mind that it either works or it doesn't...it's not like points which give you some notice when they're worn or on their way out. When the pertronix dies, it'll happen in an instant and you'll be stranded. That's why many P users keep a spare set of points or a spare PIII in the trunk (myself included)!
Jetsetsurfshop
Aug 10 2017, 04:48 PM
You guys that are using the Pertronix III, what coil and plug wires are you using?
Also, did you increase you spark plug gap?
Thanks in advance.
IronHillRestorations
Aug 10 2017, 06:20 PM
Jet, check the classifieds. I have a Pertronix SVDA distributor and coil for sale
bandjoey
Aug 10 2017, 07:13 PM
II installed on otherwise stock (blue coil) motor. 3 years not not a drop of trouble... and now it'll probably quite tomorrow.
solex
Aug 11 2019, 01:39 PM
I just installed the III and cannot seem to get the engine to idle any one have any experience with getting the III run in a stock 2.0 D-JET?
Also I'm running a stock coil, I checked the resistance and it is 2.3 ohms with no wire attached and am running Magencore Electrosport 70 SS25 200T spark plug wires.
Any thoughts or direction would be appreciated.
Regards,
Dan
porschetub
Aug 11 2019, 03:14 PM
QUOTE(solex @ Aug 12 2019, 07:39 AM)
Regards,
Dan
I've run a stock and Bosch blue coil with Ignitor 1 but pertronix matching coil with Ignitor 11, I don't know the impedance required for the Ignitor 111 but would be surprised if the stock is compatible.
Do you have the correct air gap between pickup and dizzy shaft ?,1mm from memory.
You can't run solid core leads with the newer ones as per instructions.
bbrock
Aug 11 2019, 03:45 PM
According to the Pertronix III instructions, it is compatible with any coil of 0.32 Ohms or greater so should work with stock coil.
http://support.pertronix.com/file.php?key=...1a66cdecbd8493fI recently bought and installed a Pertronix III and their matching Flamethrower III coil but am months away from firing up the engine so can't comment on how well it works.
As Ian mentioned, there is no magnetic ring under the rotor with the Pertronix III ande is no adjustment for air gap.
SteveL
Aug 11 2019, 03:53 PM
I have had a Pertronix in place of the points for 15-20 years now, must be a series 1 if that old. Never an issue.
solex
Aug 11 2019, 05:18 PM
I checked everything even called Pertronix prior to purchasing to make sure the plug wires I had were good. I will have to call them again.
I may need to downgrade to a II or I or back to good old points and condenser.
Thanks for the responses
solex
Aug 15 2019, 08:35 AM
Spoke with Carl from Pertronix.
(1) I'm on vacation and cannot confirm the stock distributor number but guessed at 0-231-174-005 (from ebay pictures) if any one can confirm that would be great, I'm not sure how many different stock distributors there are out there
When I get home:
(2) Verify that 12V is on the + of the coil
(3) There should be no other wires on the - side of the coil except the Pertronix
(4) 2.3 ohms is too high and they recommend no more that 1 ohm other wise the engine will run hot
(5) check the spark at the coil, should just at 3/8" to a ground which indicates 35k vols
(6) check the spare at the plug which should also jump 3/8" to a ground
Thought this was going to be easy and a nice upgrade...
sportlicherFahrer
Aug 16 2019, 07:12 PM
OP here. I ended up canning the Ignitor III. Never ran it actually. I seem to remember that it wouldn't allow use of a tachometer without some extra work, or some other major drawback. Went to an Ignitor II and ran it that way for a while. Now still running the II, but switched to carbs and it is driving a 6AL Digital MSD box with appropriate additional bits(Blaster 2 coil, tach adapter, 8mm wires). I have no experience with MSD and D-jet, but I'd imagine it'd be okay.
If you downgrade to a II it should run fine with D-jet.
solex
Aug 22 2019, 12:24 PM
Got it running, after checking everything I had my son start the engine while I adjusted the distributor, turned out the distributor was not 100% seated before and I did not remember the correct location.
I'm going to order their "Flame-Thrower II Coil, Epoxy Filled (45, 000 Volts, 0.6 Ohm), Black" coil part number 45111, as the Pertronix tech recommended no more than 1 ohm resistance at the coil and supposedly will give cooler running temperatures.
I will check the engine temp before I replace the coil
Rand
Aug 22 2019, 02:29 PM
Pertronix worked great for me for 20+ years. Then I got a 123 dizzy. Better yet. Points are nice to have in the glove box in case you need a backup, but surely no where near the performance of newer tech.
Al Meredith
Aug 22 2019, 02:43 PM
I've had problems with two pertronix units . I noticed the advice from pertronix that they want ONLY their unit on the 12volt side of the coil. That may have been my problem because I have the electric fuel pump plugged into the coil along with the P unit.
solex
Aug 22 2019, 04:07 PM
QUOTE(Al Meredith @ Aug 22 2019, 04:43 PM)
The tech said something similar and that they were not that keen on something else plugged into the negative side of the coil.
I just went out and checked it again an the engine started right up and the idle was very steady.
solex
Aug 31 2019, 04:45 PM
I have given up.
I order there epoxy coil with 0.6 ohms resistance and found both a vacuum leak and a fuel leak, everything has been corrected including a new cap and rotor but still am experiencing a hunting idle, bucking & pinging under acceleration.
I installed new points and a condenser, set the dwell the timing. Idle and accelerates perfectly...
I'm going to see if I can return the parts.
ndfrigi
Aug 31 2019, 05:22 PM
here is my experienced with pertronix, bought my 1st 914 75 1.8 FI last 2011. The car last registration was 2003 and been sitting for 8 years as non-op. So 2011 since I bought it, did nothing with the dizzy except just look at the inside and it is clean, so I didn’t bother changing anything except replace spark plugs and wire for the ignition system and fix all fuel lines and installed SS tunnel lines and other needs to be restored since it was a non-op for 8 years.
I was able to drive the car for more than 4 years until the pertronix failed. Installed old contacts points just to test and it did run again. And since I also have a used pertronix from my stash of dizzy, grab that pertronix and installed it and it run well again even not knowing the condition of that pertronix. Sold the car last 2017 with same pertronix. So meaning, as long you have the right or proper installation, pertronix should be better than contact point.
solex
Sep 2 2019, 04:13 PM
I have no doubt that Pertronix I & II works based on everyone's experience.
I purchased version 3 to see if it will also work and have not heard from anyone else that has it running. I'm inclined to say that it does not work with a stock D-Jet setup, this of course is not a scientific conclusion based on a single data point
Gatornapper
Dec 7 2019, 06:58 PM
My dizzy just went bad & I have MSD and see this as the perfect time to get rid of points.....just thinking of a new 009 from George with Pertronix 1875A OR Pertronix D186604 Flame Thrower dizzy for $140.....
1. Will either work with my MSD?
2. Which would be preferable - the 009 or Flame Thrower?
PS: Anyone ever heard of a mechanic
removing one of the centrifugal advance springs to radically change the advance curve? I haven't - but
one spring is gone and no where to be found - and there is no place for it to get out of the dizzy........
GN
QUOTE(solex @ Aug 11 2019, 06:18 PM)
sportlicherFahrer
Dec 7 2019, 07:13 PM
The 009 and pertronix units will "work" but they have the wrong curve and will never run properly. I'd recommend a stock unit over those, and with vacuum hooked up in a T from each carb to the advance pot, or pony up for the 123 unit that seems to be working well on these engines.
rbzymek
Dec 7 2019, 07:52 PM
I installed a Pertronix III ignitor, Flamethrower dizzy and their recommended coil on my 2056 L-Jet this past summer ($245). I have the recommended resistive plug wires. After a 10 mile warm up I would get ignition drop outs at idle which were severe enough to cause a stall. I then performed the voltage and resistance tests that they requested and it passed the tests. I initiated a warranty return and found that the replacement ignitor behaved the same way. I suspect that it could be corrected by reducing the ignitor gap but there is no adjustment. An internet search revealed that I was not the only one having drop outs when fully warmed up.
When I requested a refund from Pertronix they refused and referred me to the seller (CIP1). I am hopeful that CIP1 will provide a refund after which I will probably switch to 123Ignition.
Gatornapper
Dec 7 2019, 07:53 PM
Jim -
PRICELESS information - thank you. You know I have Weber IDF-44's, right? Not D-jet.
Now - where to connect the vacuum line? On the IDF 44's there is a very small tube for a vacuum connection at the bottom of the carbs - is this point of sufficient size?
TIA,
GN
QUOTE(sportlicherFahrer @ Dec 7 2019, 08:13 PM)
Gatornapper
Dec 7 2019, 07:57 PM
Thanks for the info.........
I'd love the 123 someday, but just out of my budget now.
Not sure what to do now......hate to stick with points......I have EI in my old '70's Triumph motorcycles.....
GN
QUOTE(rbzymek @ Dec 7 2019, 08:52 PM)
sportlicherFahrer
Dec 7 2019, 08:22 PM
I'm running with 40's on mine. Stock cam with carbs should in theory be able to use stock ignition curve was my thinking, and it hasn't been a problem. Also running MSD being triggered by an ignitor II. From what I read on the III it is incompatible with tachometers and/or ignition boxes.
I am using the small vac port near the bottom of the carb on each side. It is actually above the throttle plate, so it is ported vacuum. The vac ports from each carb need to be T'd together to prevent a pulsing vacuum signal.
Gatornapper
Dec 7 2019, 08:33 PM
Hmmm.....just thinking - my '76 2.0 was running perfectly - I cannot imagine better - with the 009 and its centrifugal advance.
How does the Pertronix change the advance curve?
What about a stock dizzy (vacuum advance) and the Pertronix?
Enquiring minds want to know.......
TIA,
GN
Gatornapper
Dec 7 2019, 08:48 PM
Jim -
Totally got you on the vacuum lines being "T'd"....was thinking my ports were below the throttle plates tho.....same level as the air mixture screws.....
Is there a thread evaluating vacuum advance performance vs. centrifugal advance performance on Type 4's using carbs?
One top 914 shop in Colorado advised me to bend the tabs in the dizzy to keep the advance from going a full 27 deg, cutting the advance back about 10 - then advancing the idle timing to about 5 to 7 degrees......he said it would improve performance between idle and about 3,000 rpm a lot......
Hadn't done that yet....
GN
QUOTE(sportlicherFahrer @ Dec 7 2019, 09:22 PM)
sportlicherFahrer
Dec 9 2019, 05:52 AM
I honestly don't have any hard data on the differences between a Bosch 009 and the flamethrower. My flamethrower ran like crap, and my stock distributor with the pertronix ignitor II driving my 6AL runs strong as hell.
As far as your 009 running fine, it all comes down to how you have your particular engine dialed in I suppose. From what I've read and experienced over the years, I don't think they have the optimal advance curve for any road going application. Fine for idle to WOT on a track, which is where they gained popularity with the big crowd. Just my opinion though.
Haven't seen a true evaluation of vac vs. no vac. That'd be interesting to see.
Gatornapper
Dec 9 2019, 08:20 AM
Seems this should be so simple - but it's not.
Seems like the least expensive path to great carb performance (Pelican: here -
https://www.pelicanparts.com/techarticles/9...iming_carbs.htm )
would be a 205AA dizzy with vacuum advance, Pertronix ignitor, and MDS with timing set at 34 deg. BTDC at 3200 rpm.
But it appears you cannot get a 205AA anywhere at a reasonable cost.
I'm reluctant to get another 009 - although at one time mine ran fine - because of comments here.....and a 123 is out of my budget and a goal someday.....
GN
QUOTE(sportlicherFahrer @ Dec 9 2019, 06:52 AM)
sportlicherFahrer
Dec 9 2019, 08:29 AM
I've also heard of folks using the 205AB from a 1.8 with good results. Still vacuum advanced, but no bottom trigger points which is a mute point. May be able to find one of those more easily and for less.
sportlicherFahrer
Dec 9 2019, 09:10 AM
Checking out the pertronix website, it looks like they make a vac advance distributor with the ignitor II in it already. Would be curious to see how well it runs on a type IV motor. Part number D182504. Can be found
on Amazon for about $176.
Gatornapper
Dec 9 2019, 10:49 AM
Decision made. Ordered new 009 dizzy from AA and 1874A Ignitor directly from Pertronix for $87.......and they told me they were 15% off last Friday......Pertronix told me the 1874A was the correct unit for the 009 and would indeed work with MSD ignition.....
We'll see what happens.....
GN
ClayPerrine
Dec 10 2019, 07:17 AM
QUOTE(Gatornapper @ Dec 9 2019, 10:49 AM)
GN
The 009 distributor has a lousy advance curve for use in a Type IV. I would not recommend using it. You will be disappointed with it.
rbzymek
Dec 10 2019, 07:46 AM
Clay,
What is the best option for a 1.8L dizzy short of 123ignition? 050? Thanks.
Dec 10 2019, 07:56 AM
009 is a great distributor, for a generator engine
ClayPerrine
Dec 10 2019, 10:52 AM
QUOTE(rbzymek @ Dec 10 2019, 07:46 AM)
Clay,
The stock 1.8L distributor also works great with carbs. If you can find an 050, it is good. But finding a cap and rotor for an 050 is not easy these days.
There is a pertronix for the stock 1.8L distributor. We have run two different ones in Betty's car for over 20 years. The first one dies because I hooked it up to the coil backwards and fried it. That was my dumb@ss move, not a fault of the pertronix. They have never even hiccuped in all that time.
I have also run the pickup coil/igniter unit from a Toyota 22RE engine. It triggered off the point cam, and was totally reliable. The Igniter module got us protested at an AX, so I switched it to pertronix.
Gatornapper
Dec 10 2019, 12:25 PM
Asked Pertronix about this - it will not fit/work in Type 4 engines. Only Type 1's.
They also told me that either the 1874A or V would work with the 009 dizzy, and either is $87 from them........someone somewhere stated that the V would not work with the 009....
GN
QUOTE(sportlicherFahrer @ Dec 9 2019, 10:10 AM)
sportlicherFahrer
Dec 10 2019, 12:33 PM
Saw reviews on Amazon and Summit of guys running them on type IV engines. Said the body of it had to be rotated to avoid the tin, and basically put the plug wires to where they make sense and in the right order.
Gatornapper
Dec 10 2019, 12:37 PM
Clay -
Thanks. Car had an 009 in it when I got it, and after I got the Weber's dialed in, it ran great - I could find no faults whatsoever putting car through all possible load tests.
As I think I noted before or elsewhere, a top 914 shop in Colorado advised me to bend the stop tabs a bit in an 009 reducing the total advance degrees, and then setting the advance to about 30 deg. at 3500 rpm.
When I win the lottery (which I don't play, but figure my odds of finding a winning ticket on the ground are about the same) I'll get a 123ignition - or when I have a bit more cash on hand in the future..... ;-)
GN
QUOTE(ClayPerrine @ Dec 10 2019, 08:17 AM)
GN
Gatornapper
Dec 10 2019, 12:52 PM
Jim -
Very interesting - but the 009 is on the way.
But I have to wonder what the advance curve looks like on it - compared to the 009......
Pertronix flat told me it would not work.....or I would have ordered it for sure......
Thanks,
GN
QUOTE(sportlicherFahrer @ Dec 10 2019, 01:33 PM)
