> Maddog 6 mount install question
Jon H.
post Nov 27 2026, 07:58 AM
Region Association: Canada
Hey fellow teeners. After 15 years I'm finally getting some progress on my 914-6. I got a 2.4L back in the spring and hopefully this weekend I can get it installed. But I'm not sure how to proceed. I have the Maddog 914-6 engine mount. I have the instructions with the measurements but I'm not sure if I have to first bolt it on to the firewall and then install the engine/tranny to check for fitment (not even sure what I would be checking). Then if all is good, remove engine/tranny and weld the mount to the firewall. Or do I just bolt it in using the measurements in the instructions and weld it and hope for the best?
Regards,
Jon h.
post Nov 27 2026, 08:08 AM
15 yrs ?? What version do you have ?? there is a kit someone made and its lower for racing,,Hope you dont have that one... Pics are 1000 words.. Good Luck sixnotfour
mate914
post Nov 27 2026, 08:33 AM
Matt
QUOTE(Jon H. @ Nov 27 2026, 09:58 AM) *
Regards,
Jon h.
If it sits to high or low, your engine seal wont ling up and your lid will not close....
Jon H.
post Nov 27 2026, 11:22 AM
QUOTE(sixnotfour @ Nov 27 2026, 06:08 AM) *
Yeah, 15years......sigh. Though I did have another 914 I was driving that I used for part for this car. But it is a current mount I bought from PMB a few months ago.
Jon h.
Jon H.
post Nov 27 2026, 11:33 AM
[/quote]
[/quote]
Then i guess I should mount the motor/transmission before final welding? One issue is that I don't have the 914-6 engine tin yet. I only have the 911 tin.
Jon H.
post Nov 27 2026, 11:48 AM
QUOTE(Jon H. @ Nov 27 2026, 12:22 PM) *
Jon h.
PMB installs them all the time. Just give them a ring and ask them if the instructions are accurate or need to be modified.
1 Members: 930cabman
- Lo-Fi Version Time is now: 27th November 2026 - 01:34 PM
