| burlybryan |
Nov 26 2026, 01:07 PM
Member ![]() ![]() Group: Members Posts: 181 Joined: 25-May 20 From: Saint Paul Member No.: 24,311 Region Association: None
I'm sussing out my recently rebuilt stock 2.0 (with FI) and when I first start it, I have to give it some gas for about 3 or 4 minutes before it will idle. When first starting it, it just falls flat and kills. It's in an indoors shop, so it's not cold enough to engage the cold start injector (which was tested and cleaned by Mr. Injector).
After a few minutes it will idle perfectly on its own at 900 (initially it was about 1200 when warm, but I turned the idle screw about 1/8 turn to have it settle at 900). Some details: 123 Bluetooth distributor. Timed to 27 degrees at 3500 rpm (hose off, but not capped - not sure if this is critical. Didn't intentionally have it off but it fell off when adjusting the diz). Currently, it doesn't have any advance at idle. Advance starts at 1500 rpm. Lots of 123 threads I've read mention up to 8 degrees at idle, but these are usually 2056 or bigger engines. Would some early/initial advance help cold idle? All new harnesses. Used, but tested and correct model numbers of the various FI components. The AAR is getting 12v and is open when cold. I can blow through it. When the car has warmed up 5-10 minutes, there is still a little bit of suction on the upstream hose. Is this normal? Besides timing, I'm not sure where to look next. Or is this just normal for a fuel injected Djet? Thanks! |
Nov 26 2026, 01:57 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,839 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
What is your cht resistance when cold? Is this a 1.8 turned into a 2.0 or is this a stock 2.0?
Lo-Fi Version | Time is now: 27th November 2026 - 01:22 AM |
