| lazytv |
Nov 25 2026, 11:20 AM
Newbie ![]() Group: Members Posts: 5 Joined: 16-November 21 From: canada Member No.: 26,079 Region Association: None |
Hello
I have a shell that is 95% rust free and restored from previous owner. The rear panel needs work as well. From some of you that have done restoration, what is best way to tackle the rear panel. Replace entire thing or cut out sections. See photos. it's not terrible but definitely needs addressing. Attached thumbnail(s) |
| lazytv |
Nov 25 2026, 11:23 AM
| Montreal914 |
Nov 25 2026, 08:22 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,231 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California
It is not really easy to see on the pictures with the flat black paint but it looks like the tail lights seal area is gone and some deep pitting in the center section potentially due to an added reflector at some point? Is the rest in good shape?
Might be easier to replace only these areas? (IMG:style_emoticons/default/idea.gif) The real bodywork people will chime in. |
| rjames |
Nov 25 2026, 08:23 PM
I'm made of metal ![]() ![]() ![]() ![]() Group: Members Posts: 4,495 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest
wire wheel it and see how much metal is left.
| bkrantz |
Nov 25 2026, 08:40 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,827 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains
Removing the whole thing means dealing with getting the joins with the rear fender panels (inner and outer) just right so the tail lights fit properly.
How is the seam with the trunk floor? |
Nov 25 2026, 09:02 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,020 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
I would dig some more. If there is rust on a vertical surface, there’s got to be rust on the horizontal surfaces, especially down low.
Lo-Fi Version | Time is now: 25th November 2026 - 11:22 PM |
