| GeorgeKopf |
Nov 24 2026, 09:03 PM
Member ![]() ![]() Group: Members Posts: 271 Joined: 9-February 21 From: Princeton, NJ Member No.: 25,186 Region Association: MidAtlantic Region |
I have a WO engine case and an EA engine case.
I also have: a set of weber dual 40mm carburetors a pair of stainless steel 2.0 heat exchangers a pair of stock 2.0 heads All of the rest of my engine components are from a 1.7 liter (crank, cam, pistons and rods) I want to keep the factory heat exchangers so that I can have cabin heat. I could build the EA case to be a naturally aspirated 2056. I could build the WO case to be a fuel injected 2270. Either way, I need to buy a new crank, cam, rods and pistons. I understand that the 2270 will be hobbled by the stock heat exchangers, but I also believe that it will have more torque making the car more responsive. I could build the 2056 first, get the car on the road and then worry about the 2270 if I think it necessary. I'm not looking for a definitive answer. I'm just soliciting the communities expert opinions and hoping to have a conversation. Thanks. George |
Lo-Fi Version | Time is now: 24th November 2026 - 10:37 PM |
