| DennisV |
Nov 22 2026, 09:01 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,069 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California
Can anyone share their success, or failure, in using specific timing lights with a CDI system?
I am looking at digital timing lights with adjustable advance feature and built-in tach. My understanding is this can be an affective workaround for setting ATDC where the flywheel is missing timing marks (914-6). Our car has CDI. I am reading the CDI can cause issues with these highfalutin timing lights. Unfortunately, I'm not finding any manufacturer that claims compatibility. In fact, most say something like: QUOTE Your timing light is designed for use on all 12-volt negative ground vehicles equipped with conventional breaker point and electronic ignition systems. I suspect CDI is not considered "conventional". Otherwise, I'll probably just buy one and hope that if it doesn't work, I don't damage it and can return it. As I understand it, dwell isn't important with CDI, so I'll probably hope for a Black Friday sale on an Innova 3568 or Innova 5568. |
Lo-Fi Version | Time is now: 22nd November 2026 - 07:34 PM |
