| Boothy |
Nov 22 2026, 08:28 AM
Member ![]() ![]() Group: Members Posts: 114 Joined: 17-January 19 From: Abington, MA Member No.: 22,805 Region Association: North East States |
Cheers All,
Corrected my rich problem last spring where I re-jetted and it was too rich so it smoked a lot. It's cleaned out now but it still revs high when driving. Sitting it will idle comfortably at 1000. And when I lay on the the throttle is goes nicely. But when I let off it's reving high. I'm thinking I need to drop the idle jet but advice will be appreciated. 1700 punched out to 2000. Weber 40s. 123 Ignition. Heavy springs on the linkage. Thanks in advance! |
Nov 22 2026, 10:59 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,835 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
Is the 123 Bluetooth? If it is how abrupt is the curve in the 123? Checked for vacuum leaks? Not much of a carb person but vacuum leaks are always possible...
| 930cabman |
Nov 22 2026, 12:31 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,887 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
throttle linkage?
| campbellcj |
Nov 22 2026, 02:18 PM
I can't Re Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,726 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California
^^^ I agree, sounds more like a sticking linkage or a broken/disconnected return spring vs an idle jet issue. If you rev it by hand directly on the linkage does it drop back down properly?
| cgnj |
Nov 22 2026, 05:01 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 741 Joined: 6-March 03 From: Medford, NJ Member No.: 403 Region Association: None
3rd vote for linkage geometry.
Lo-Fi Version | Time is now: 22nd November 2026 - 07:34 PM |
