> Stuck lower shock bolt
seanpaulmc
post Nov 21 2026, 04:42 PM
Stuck bolt. Any home remedies on this one?
Driver side rear lower shock bolt.
Won’t budge.
Doesn’t turn in the hole.
Tried a C clamp.
Tried BFH, as best as possible with the awkward angle (rotor removed).
Will continue to add penetrant.
Heat?
Find someone with a press and take the whole trailing arm? Ugh!
Other side was stubborn.
This side just says No Way!
TIA World.
Cheers,
Sean
- Lo-Fi Version Time is now: 21st November 2026 - 06:28 PM
