> clutch release concerns
jmargush
post Nov 20 2026, 06:53 PM
I put a high performance clutch in my car before this past driving season.
High performance in that the lining is a bit grippier and the pressure plate springs are stronger.
a while after installing it I noticed it felt like it wasn't releasing completely, so I tightened the cable some more.
After 3 or 4 months of driving I am experiencing again the clutch not releasing all the way. I can feel a tugging when i start the car in gear, and if I come to a stop after driving and try to get it into reverse it just grinds.
Maybe it is in my head but the pedal feel doesn't feel quite the same.
I am getting the feeling like possibly the bracket in the tunnel is starting to let go from the extra force of the stronger springs.
Does this sound like a logical possibility?
How far should the release fork move to get the clutch all the way off the flywheel?
or do I need to investigate with a borescope in the tunnel to see if I can see any thing?
stownsen914
post Nov 20 2026, 09:12 PM
Tell us a little more about the clutch. Uprated version of stock type 215 mm?
Jack Standz
post Nov 21 2026, 02:18 AM
Suggest you don't just guess if the clutch is fully releasing.
Take the time to jack one side of the rear of the car enough that one of the rear tires is off the ground. Use jack stands and release the parking brake. Put the transmission in gear and see if you can turn the wheel. Compare with trying the same with the transmission in neutral and if the clutch pedal is fully pressed.
Wild guess is the bushing in the throwout fork is worn or misaligned (different clutch travel from your non-stock clutch/pressure plate) so much that the shift fork is hitting the transmission housing before the clutch is fully released. So, take a look at the transmission case and see if the clutch fork is hitting the case and preventing the clutch from releasing. If things are OK mechanically, adjust the cable until you have the proper free play and sufficient travel.
There are other possibilities like the one you mentioned about the tube in the tunnel being broken, etc. Hope you get her fixed up soon! (IMG:style_emoticons/default/biggrin.gif)
jmargush
post Nov 21 2026, 03:29 AM
Unfortunately I don't have or remember exact specs on the clutch. Sizes was the same just lining material and strength of springs were different.
The fork is not hitting the transmission case at this point so I will try tightening the cable.
I'll also take a look at checking the release in the manner outlined.
jmargush
post Nov 21 2026, 03:30 AM
Throw out bearing was new when clutch was installed
5 User(s) are reading this topic (5 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 21st November 2026 - 04:16 AM
