> WTB: Adapter plate for engine and starter or bell housing, I'm building out my engine and want to test fire it on the stand.
GeorgeKopf
post Nov 17 2026, 08:14 PM
There are several ways to connect a type 4 engine to a standard engine stand. I've seen pictures of adapter rings that have a hole for mounting the starter. This would allow me to build the engine and get it running while on the stand.
Another option is to cut a bell housing from a compatible transmission. I'm hoping somebody has one lying around that they aren't using that I could buy, rent or borrow.
Thanks.
George
post Nov 18 2026, 02:36 AM
@GeorgeKopf
' date='Nov 17 2026, 08:14 PM' post='3278832']
Thanks.
George
[/quote]
I have a bell housing from a sportomatic that should work for you. I have always put the engines on the ground with a couple of 4 x 4s under the case.
Do you have a really solid engine stand? The bell housing will make for a lot of extended overhang weight.
sixaddict
post Nov 18 2026, 06:32 AM
Maybe not understanding your question but I just used an empty gearbox ….( on a six)
No muss no fuss. It’s not like they are in short supply. Expect I’m missing something.
friethmiller
post Nov 18 2026, 07:21 AM
QUOTE(GeorgeKopf @ Nov 17 2026, 08:14 PM) *
Thanks.
George
George, You might want to consider building a separate test stand and just mount the transmission and exhaust for the break-in. Simple to construct and once you’re satisfied/ fix any leaks/ set timing, you can take the entire assembly and mount it straight into the car when your done. Here’s a pic of mine. This is just scrap wood and some cheap left-over spray paint that was 15 yrs old. I used a jack cart to take off the engine stand over to the test stand, and then used a floor jack with TR’s lift plate to take it over to car for the install.
9 User(s) are reading this topic (7 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 18th November 2026 - 08:53 AM
