| seanpaulmc |
Nov 15 2026, 05:05 PM
Member ![]() ![]() Group: Members Posts: 480 Joined: 6-December 16 From: Orlando, FL Member No.: 20,649 Region Association: South East States
Hi World -
Looking for some advice from those who’ve gone before. TIA I am beginning to plan installation of the rear sway bar brackets. ![]() ![]() 1. Should the bracket be bent to flatten against the trunk pan for welding? Same both sides of course. I do not have the shock bolts in yet. One side is proving quite difficult to extract. I say this because of the next question. 2. Does the sway bar need to be mocked up (installed) to get alignment between each side, or is the alignment forgiving enough to eyeball? Thank you |
| L-Jet914 |
Nov 15 2026, 05:27 PM
Member ![]() ![]() Group: Members Posts: 438 Joined: 24-October 12 From: Davis, CA Member No.: 15,080 Region Association: Northern California |
Hi World - Looking for some advice from those who’ve gone before. TIA I am beginning to plan installation of the rear sway bar brackets. ![]() ![]() 1. Should the bracket be bent to flatten against the trunk pan for welding? Same both sides of course. I do not have the shock bolts in yet. One side is proving quite difficult to extract. I say this because of the next question. 2. Does the sway bar need to be mocked up (installed) to get alignment between each side, or is the alignment forgiving enough to eyeball? Thank you https://www.pelicanparts.com/techarticles/9...4_rear_sway.htm Hope this helps. (IMG:style_emoticons/default/smile.gif) |
| bkrantz |
Nov 15 2026, 07:33 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,819 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains
I reinforced the inside of the rear floor panel above the location for the bracket.
Attached thumbnail(s) |
| bkrantz |
Nov 15 2026, 07:38 PM
Here is a shot from underneath. When I cut out the rear floor I left the brackets attached to the cross member.
| Front yard mechanic |
Nov 15 2026, 09:35 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,483 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None
Mock it in place first. I drilled through the bracket and the floor put a small bolt then removed it after welding and welded the hole. That worked for me
Lo-Fi Version | Time is now: 16th November 2026 - 03:33 AM |
