| DennisV |
Nov 14 2026, 07:50 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,059 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California
In the process of trying to disable our fuel pump, I realized I didn't know what everything on the engine relay board was for. This thread was some help, but I'm still not 100%.
Can anyone confirm or clarify I have this labeled correctly? What are the fuses protecting? P.S. I never did find a relay or fuse that disabled the fuel pump. (IMG:style_emoticons/default/confused24.gif) ![]() |
| barefoot |
Nov 14 2026, 08:06 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,571 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States
| DennisV |
Nov 14 2026, 08:08 AM
Thanks but that appears to be a 914-4 board. it is different. |
| rgalla9146 |
Nov 14 2026, 09:49 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,021 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None
Dennis power for the fuel pump on a six does not go through the engine harness,
The round plug for the fuel pump comes from the chassis harness. The 914 6 powers the fuel pump directly from the ignition switch without a fuse. Ground is from a gang connection near the relay board |
Lo-Fi Version | Time is now: 14th November 2026 - 01:16 PM |
