| 914rrr |
Nov 11 2026, 11:54 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,131 Joined: 1-July 03 From: McMinnville, TN Member No.: 874 Region Association: South East States |
Seeking lower engine tin on the passenger side and a pair of rear shocks w springs for my 75 1.8.
I could also use a thermostat, bracket, cable, wheel, driver side flap w rod, bushings, etc. assembly for same. I can possibly pick these up as I commute weekly from McMinnville, TN to Cincy / N. KY areas. |
| 914werke |
Nov 11 2026, 05:30 PM
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,796 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest
Do you mean the under cylinder tin or the air deflector for that side?
| 914rrr |
Nov 11 2026, 08:38 PM
| GaroldShaffer |
Nov 11 2026, 09:51 PM
You bought another 914? ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 7,664 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None
I have these. Obviously they need cleaned up and painted. Thermostat tested and works .pictures shows cold and heated up with heat gun. Will need to swap the cable with the spare in the pictures. I dont have a good wheel. Let me know if you are interested.
Attached thumbnail(s) |
Lo-Fi Version | Time is now: 11th November 2026 - 09:56 PM |
