| PDXBob |
Oct 30 2026, 04:25 PM
Member ![]() ![]() Group: Members Posts: 66 Joined: 16-May 20 From: Portland Oregon Member No.: 24,272 Region Association: Pacific Northwest
I have a 1975 914. Electrically it’s pretty sorted out. No bad wires, fuses all good, no major add-ons like amps, other items. No parasitic draws. However twice now when I’ve disconnected battery to do electrical work, when I reconnect the negative battery cable I’ve had a dead battery. Both times disconnected for about one week.
When I then put on battery trickle charger for a while it charges up, then runs fine(starts every time, doesn’t go dead). First time I’ve ever had a battery go dead when negative cable is disconnected. Bad battery or ??? Your thoughts appreciated! PDXBob |
| fixer34 |
Oct 30 2026, 04:54 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,481 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest
I would put it on the charger for a couple days then take it to your FLAPS and have them run a load test.
Oct 30 2026, 05:14 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,155 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
I would put it on the charger for a couple days then take it to your FLAPS and have them run a load test. (IMG:style_emoticons/default/agree.gif) I’ll go further; battery is scrap. Not uncommon for a battery have an internal short and to be able to take a surface charge and even be able to do a start. But when left over a period of time the internal short drains the battery. Just had this happen with a small 12v battery of the type used for emergency lighting, etc. Has happened to me countless times over my lifetime with car batteries. |
| dtmehall |
Oct 30 2026, 05:30 PM
Member ![]() ![]() Group: Members Posts: 394 Joined: 21-December 23 From: Michigan Member No.: 27,808 Region Association: Upper MidWest |
(IMG:style_emoticons/default/agree.gif) with Superhawk996
Lo-Fi Version | Time is now: 30th October 2026 - 05:36 PM |
