| cabrioartie |
Oct 17 2026, 05:08 PM
Newbie ![]() Group: Members Posts: 38 Joined: 8-October 24 From: Las Vegas, NV Member No.: 28,400 Region Association: None
Finally was able to get under the car for an inspection.
Found one side has a cap on what I believe is the heater control and the other side does not. Am I missing a cap or should only one side have this cap? Oh, Driver side has the cap, Passenger side does not. |
| fixer34 |
Oct 17 2026, 05:25 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,476 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest
Missing something? Yes, the cap on the passenger side. Not sure how it came off...
| dtmehall |
Oct 17 2026, 05:33 PM
Member ![]() ![]() Group: Members Posts: 382 Joined: 21-December 23 From: Michigan Member No.: 27,808 Region Association: Upper MidWest |
without the cap, i think that it's dumping heat towards the engine
| cabrioartie |
Oct 17 2026, 05:42 PM
Any body have a part number for this cap?
| dtmehall |
Oct 17 2026, 06:01 PM
there isn't one. it's part of the heat control valve assembly
| bdstone914 |
Oct 17 2026, 08:48 PM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,410 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
@dtmehall
date='Oct 17 2026, 04:33 PM' post='3275442'] without the cap, i think that it's dumping heat towards the engine [/quote] Not really. It is always dumping heat in that area. There is a bulletin to remove that cap and attach a hose to direct heat away from thr fuel pump on pre 75 cars. The air under the car is flowing toward the back of the car. Cool is above the tin for cooling fan and induction. |
| bdstone914 |
Oct 17 2026, 08:50 PM
Lo-Fi Version | Time is now: 17th October 2026 - 09:36 PM |
