| andrewvolsen |
Oct 16 2026, 01:32 PM
Member ![]() ![]() Group: Members Posts: 51 Joined: 6-December 09 From: Santa Barbara Member No.: 11,099 Region Association: Central California |
I acquired a fairly large haul of 914 parts last night in preparation for my next 914 project car. Today I started sorting through the first truck load of it, and I could use some help identifying a few items.
I believe these are factory front sway bars, correct? Attached thumbnail(s) |
| andrewvolsen |
Oct 16 2026, 01:34 PM
I think the top sway bar is a factory rear sway bar, but I'm not sure about the other two. Any suggestions?
| andrewvolsen |
Oct 16 2026, 01:49 PM
914 struts with rotors modified for studs in a 5 lug pattern?
| andrewvolsen |
Oct 16 2026, 01:52 PM
Early 911 Boge strut housings?
| andrewvolsen |
Oct 16 2026, 02:00 PM
Later 911 strut assemblies (SC or Carrera)?
| andrewvolsen |
Oct 16 2026, 02:20 PM
Rear trailing arms with 914 hubs drilled for 5 lug bolts. Does anyone recognize what the brake calipers and vented rotors are from?
| Luke M |
Oct 16 2026, 03:31 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,612 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States
Looks like you have all front factory sway bars (16 mm) . 1 factory rear sway bar ( the one with the ball ends ) , the other 2 are weltmeister rear 914 sway bars.
The front struts you can look up the part #'s and it should say what they go to. The rear 914 parts look like a hybrid of 914 and 911 parts. brakes are 911 but hubs look to be 914 modified to 5 lug but using bolts? |
Oct 16 2026, 03:39 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,934 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
The spindles on the front struts are so rusty, they are trash. They have bearing surfaces in them that are ruined by the corrosion. Other than the sway bars and maybe the front 911 hubs, the rest looks to be scrap.
| andrewvolsen |
Oct 16 2026, 06:04 PM
The spindles on the front struts are so rusty, they are trash. They have bearing surfaces in them that are ruined by the corrosion. Other than the sway bars and maybe the front 911 hubs, the rest looks to be scrap. I hit them with some scotchbrite and water and they seemed to clean up ok. I don't have any wheel bearings on hand to check if the inner races still fit tightly, though. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 16th October 2026 - 07:58 PM |
