> Battery charging without ALT light, What’s going on?
VaccaRabite
post Sep 30 2026, 02:06 PM
En Garde!
A friend of mine had his battery pop in his 914. Battery acid everywhere. We got it running last weekend after a year of sitting.
Of note, the alternator light never turns on. BUT, the car is charging the battery at 13.9 volts. How is this possible? My guess is that he has a damaged or failing diode in the alternator, but I thought the battery COULD not charge without the alternator light turning on. So I’m confused.
Thanks
Zach
Artfrombama
post Sep 30 2026, 03:38 PM
Artfrombama
If you have an old battery that never fully charges, the alternator will continue to try to charge resulting in gassing and the potential to explode.
VaccaRabite
post Sep 30 2026, 04:41 PM
En Garde!
Battery didn’t explode persey. But it did spray acid over the engine bay and was on its way to exploding.
Battery has been replaced. As have all the affected wires and switches.
So now the car is running and driving and charging. But the alternator light never turns on. And this does not make a lick of sense to me.
Zach
SirAndy
post Sep 30 2026, 04:45 PM
Resident German
Wait, i'm confused. The alternator light is supposed to be off when the car is running.
Are you saying it doesn't come on with the key on but the engine off?
Does he even have a bulb in there? Did anyone bypass the light? I have seen so much hacked wiring in 914s.
post Sep 30 2026, 04:51 PM
Please clarify, how/why would a battery pop or spray acid? This one is new to me.
being very overcharged?
VaccaRabite
post Sep 30 2026, 05:02 PM
En Garde!
Not my car and I’m currently 100ish miles from it.
I’m not clear on why the battery popped, but I suspect overcharging.
On key in, the alternator light does NOT turn on. It stays off throughout startup and driving. By everything I know this means the car should not be able to charge, but measuring across the terminals at idle he’s making 13.9 volts. When the car is off it settles at 12.6 volts.
Zach
VaccaRabite
post Sep 30 2026, 05:05 PM
En Garde!
QUOTE(SirAndy @ Sep 30 2026, 06:45 PM) *
Correct. The light never turn on.
He replaced the light with another bulb today and it remains off.
None of the bulbs on this car are LED.
The light used to come on normally as far as I know. I’ve driven the car and that’s something I would have noticed.
But the alt is getting field from somewhere I guess. Just not the right place.
Zach
- Lo-Fi Version Time is now: 30th September 2026 - 11:04 PM
