> Happy 9/30 if you are celebrating, Enjoy these forced induction cars
Maltese Falcon
post Sep 30 2026, 01:04 AM
If you take part in forced induction Day, enjoy the 930 (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/driving-girl.gif)
Pic @photomatyeux
post Sep 30 2026, 04:55 AM
Yes indeed, aka widowmaker
It took me awhile to have the guts to run WOT, and its a rush for sure
enjoy safely
Spoke
post Sep 30 2026, 07:54 AM
Jerry
My '86 930 is in the final phase of engine restore at The 9 Store.
Internal engine parts replaced:
camshaft flange cover
dowel pin for cam gear
barrel nut for camshaft oil line
camshaft oil line restrictor
alternator shim washer
camshaft thrust washer
rod bearing set
#8 nose bearings
camshaft drive gear
woodruff key
main bearing set
head studs - canyon
engine gasket set - case
engine gasket set - heads
oil pressure relief valve
plug for oil pressure relief valve
guide sleeve for oil pressure relief
spring for oil pressure relief valve
lock plate
oil return tubes
exhaust valves
intake valves
rocker arm shaft
fuel injector
intake manifold flange
intermediate shaft bearings
rocker arm shaft bolt
bushing for rocker shaft bolt
nut for rocker shaft bolt
rocker arm shaft o-ring
timing chain
timing chain rail (5)
timing chain rail (1)
valve adjusting screw
mahle p & c's
oil line banjo bolt
New SC turbo cams
Refurbished rockers
Rocker locks
Other items replaced/restored
Turbo refurbish
New engine electrical harness
Crank-fired Coil on Plug
Clewett Flat Fan Belt
Fuel distributor refurbish
Replace tin rubber gaskets
Transmission restore
New clutch/PP/clutch cable
Replace heat flappers
PMB restore of all 4 calipers
CVJ Axles Restore half shafts
Spokeworks RTS-Brake modules lock rear turnsignal and brake together
Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image
infraredcalvin
post Sep 30 2026, 08:28 AM
Distracted Member
Mine! 76 Turbo Carrera
post Sep 30 2026, 09:24 AM
How does it go, date Italian, marry ......
nobody ever said a 930 is a cheap date, but they do rock like no other
(IMG:style_emoticons/default/piratenanner.gif)
- Lo-Fi Version Time is now: 1st October 2026 - 09:41 AM
