| nivekdodge |
Sep 24 2026, 07:12 PM
Member ![]() ![]() Group: Members Posts: 341 Joined: 28-August 21 From: Pittsburgh Pa Member No.: 25,860 Region Association: MidAtlantic Region
One of the first things I remember when i started working on the first one was looking at the clutch pedal and saying to myself, " I'll probably learn why that rod is threaded like that." So clue me in
Kevin |
| Shivers |
Sep 24 2026, 08:00 PM
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,608 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
One of the first things I remember when i started working on the first one was looking at the clutch pedal and saying to myself, " I'll probably learn why that rod is threaded like that." So clue me in Kevin This sounds reasonable: "Kinematic Engineering & "Over-Center" Action: The 914 pedal cluster utilizes a heavy assist spring. The clutch needs to be precisely dialed in so that the spring passes an "over-center" point during the first third of its travel. This reduces the physical foot effort required to hold the pedal down. A fixed cast pedal wouldn't allow the precision needed to align the pedal perfectly with this mechanical sweet spot." |
| dtmehall |
Sep 24 2026, 08:54 PM
Member ![]() ![]() Group: Members Posts: 369 Joined: 21-December 23 From: Michigan Member No.: 27,808 Region Association: Upper MidWest |
watch this video starting at 11:40 and again at 13:00
this should help with your install https://www.youtube.com/watch?v=-u280fQFhGQ |
| bdstone914 |
Sep 24 2026, 09:04 PM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,390 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
One of the first things I remember when i started working on the first one was looking at the clutch pedal and saying to myself, " I'll probably learn why that rod is threaded like that." So clue me in Kevin This sounds reasonable: "Kinematic Engineering & "Over-Center" Action: The 914 pedal cluster utilizes a heavy assist spring. The clutch needs to be precisely dialed in so that the spring passes an "over-center" point during the first third of its travel. This reduces the physical foot effort required to hold the pedal down. A fixed cast pedal wouldn't allow the precision needed to align the pedal perfectly with this mechanical sweet spot." Sounds like bad Ai. The clutch spring is very weak and provides almost no assist. The spring takes up the slack in the cable. It only takes 5-10 pounds of pressure to depress the pedal with a stock pressure plate. The threaded end of the clutch pedal allows for a small amount of height adjustment. The clutch does need to be properly adjusted to minimize the pressure to depress it. |
| dtmehall |
Sep 24 2026, 09:12 PM
sorry, i mesread his first post
| dtmehall |
Sep 24 2026, 09:18 PM
Lo-Fi Version | Time is now: 24th September 2026 - 11:52 PM |
