| NickC809 |
Sep 20 2026, 05:38 PM
Newbie ![]() Group: Members Posts: 2 Joined: 20-July 24 From: Grass Valley, CA Member No.: 28,250 Region Association: Northern California |
I finally tore down the extra engine I had laying around and have been slightly befuddled and bemused by my findings. Based on some very rudimentary measurements it appears I have a stroke of roughly 66mm and my piston/jug diameter is 90mm. The heads are also stamped with 1.7 part numbers. Interestingly, my case is stamped with GA. This is my first type 4 tear down and I am looking for my findings to be validated as it seems absurd to de-stroke and de-displace a 2.0.
Find an album of my rough measurements here. Did I measure wrong? Am I a fool? All things are possible. https://photos.app.goo.gl/fV3hudrPNDsx4C9o7 |
| Shivers |
Sep 20 2026, 06:14 PM
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,591 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
I finally tore down the extra engine I had laying around and have been slightly befuddled and bemused by my findings. Based on some very rudimentary measurements it appears I have a stroke of roughly 66mm and my piston/jug diameter is 90mm. The heads are also stamped with 1.7 part numbers. Interestingly, my case is stamped with GA. This is my first type 4 tear down and I am looking for my findings to be validated as it seems absurd to de-stroke and de-displace a 2.0. Find an album of my rough measurements here. Did I measure wrong? Am I a fool? All things are possible. https://photos.app.goo.gl/fV3hudrPNDsx4C9o7 Usually it is a W or EA 90x66 is a 1.7. I built a 2.0 from my 1.7, a brand new TRW valve let go and destroyed that poor little engine. So I went out and found a factory replacement with no numbers. I would have taken a 1.7 or a 2.0 case if that was what I found. So I would not worry too much about the GA. I built a 1911 with my 1.7 first, a cam and some head work and a set of 40 IDF's and that little engine sang. |
| NickC809 |
Sep 20 2026, 06:39 PM
Usually it is a W or EA 90x66 is a 1.7. I built a 2.0 from my 1.7, a brand new TRW valve let go and destroyed that poor little engine. So I went out and found a factory replacement with no numbers. I would have taken a 1.7 or a 2.0 case if that was what I found. So I would not worry too much about the GA. I built a 1911 with my 1.7 first, a cam and some head work and a set of 40 IDF's and that little engine sang. My plan for this engine was to bump it up to a 2056 assuming it was actually a 2 liter like the stamp claimed it was. My current 2.0 is starting to get a bit tired and having a spare known good engine built over the winter seemed like the move. Now it is just a bit of a disappointment to find I will need a whole lot of extra work and extra parts to get the small displacement bump I was hoping for. On that note, anyone selling a known good 2.0 crank and con rods? |
Sep 20 2026, 09:01 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,070 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
it seems absurd to de-stroke and de-displace a 2.0. Really not surprised in the least. Welcome to the world of DAPO (IMG:style_emoticons/default/stromberg.gif) that is terribly common in the VW / 914 hobby. These cars were cheap entry level cars often owned by people that just did what they had to do to keep them running. If that meant you had a damaged 1.7L case and your buddy had a GA case sitting around - that’s what you used. Similar to how you find 914s all the time with VW Bus cases and/or low compression bus pistons in them. |
Lo-Fi Version | Time is now: 20th September 2026 - 09:53 PM |
