| robkammer |
Sep 13 2026, 02:31 PM
Robbo ![]() ![]() Group: Members Posts: 287 Joined: 7-January 21 From: Vermilion Ohio Member No.: 25,049 Region Association: NineFourteenerVille |
Brain trust: I have a bout 60 miles on the LE motor and it's running pretty well. I have the regulator that came with the car, age is unknown. I am getting voltage readings anywhere between 12.6 to 14.2 at the battery depending on the rpm and temperature. My questions: Pelican shows a Hella unit that looks just like to one I have. Are there any solid state units out there that would be better to have? I don't have a spare so I'm going to order whatever is recommended, if for nothing else but to have a spare. BTW, the alternator looks to be a relatively new addition, prior to my taking stewardship, it's a Bosch reman.
Robbo |
| porschetub |
Sep 13 2026, 03:09 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,168 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Brain trust: I have a bout 60 miles on the LE motor and it's running pretty well. I have the regulator that came with the car, age is unknown. I am getting voltage readings anywhere between 12.6 to 14.2 at the battery depending on the rpm and temperature. My questions: Pelican shows a Hella unit that looks just like to one I have. Are there any solid state units out there that would be better to have? I don't have a spare so I'm going to order whatever is recommended, if for nothing else but to have a spare. BTW, the alternator looks to be a relatively new addition, prior to my taking stewardship, it's a Bosch reman. Robbo The Hella one made in china appears to be the same one sold for some time by them that I can confirm doesn't fit properly ...whey they continue to sell them is beyond me : (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/headbang.gif) . |
| 914Sixer |
Sep 13 2026, 06:13 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,563 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
Here you go >Real Bosch. Only place I know you can get them now. Shows listing for Opel but don't worry. $50 plus shipping then import tax. Click to open .
Attached thumbnail(s) |
Sep 13 2026, 06:25 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,729 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
| pfreiburger |
Sep 13 2026, 06:29 PM
Member ![]() ![]() Group: Members Posts: 148 Joined: 6-October 20 From: Fond du Lac, WI Member No.: 24,738 Region Association: None
Hello - Does anyone make an internal regulator alternator for the 914-4?
| Ishley |
Sep 13 2026, 06:52 PM
Member ![]() ![]() Group: Members Posts: 362 Joined: 4-October 21 From: Clarendon Hills Il Member No.: 25,957 Region Association: Upper MidWest
I use this one I bought on Amazon. Works fine and is adjustable. Plugs in and was a direct swap. I installed it last year… 3k miles with no issues.
| scottthephotog |
Sep 13 2026, 07:28 PM
Member ![]() ![]() Group: Members Posts: 202 Joined: 20-November 18 From: Louisville, TN Member No.: 22,667 Region Association: Southwest Region |
I also just bought one of those voltage regulators off of Amazon. So far I haven't had any issues and it is nice that it is adjustable.
| dtmehall |
Sep 13 2026, 08:41 PM
Member ![]() ![]() Group: Members Posts: 359 Joined: 21-December 23 From: Michigan Member No.: 27,808 Region Association: Upper MidWest |
is that the white adjusting screw on the bottom?
| Ishley |
Sep 13 2026, 09:25 PM
Yes. I set it with my digital meter which is more accurate than my console gauge.
Lo-Fi Version | Time is now: 14th September 2026 - 04:24 AM |
