| gbp808 |
Sep 10 2026, 05:50 PM
Newbie ![]() Group: Members Posts: 4 Joined: 15-February 23 From: hawaii Member No.: 27,162 Region Association: None |
Hi All, just started working on a new-to-me 1975 914 2.0 rust bucket. Started by trying to start her up, had a good crank and brief start but carbs overflowing gas. Carbs rebuilt but now brief crank, then a few solenoid? clunks and now nothing. Only 0.2 v at the starter yellow wire (I did pull all the fuses since the wipers wouldn't stop and a lot of flashing dash lights). I know the eyes are rolling and I am going to be advised to check grounds, starter switch etc, but before I do that, is there something obvious I am missing? (seat belt interlock is spliced) Could I put 12V direct to the yellow lug to check the starter?
Thanks! |
Sep 10 2026, 05:53 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,722 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
Yep, just make sure you are not under the tire.
If I remember right the fuse for the ignition is in the middle of the fuse bank. |
Sep 10 2026, 05:54 PM
Oh, and the ignition switch itself is notorious for breaking. Super easy to replace though.
Lo-Fi Version | Time is now: 11th September 2026 - 05:07 AM |
