| Flyinlow |
Aug 28 2026, 09:29 AM
Flyinlow ![]() ![]() Group: Members Posts: 164 Joined: 17-October 20 From: British Columbia, Canada Member No.: 24,774 Region Association: Canada
What would cause the odometer to move faster than the distance you are travelling?
| Shivers |
Aug 28 2026, 09:49 AM
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,561 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
| DC_neun_vierzehn |
Aug 28 2026, 11:29 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 677 Joined: 16-November 20 From: Coastal Delaware Member No.: 24,893 Region Association: MidAtlantic Region
How much is it off?
Running different size tires than original specs will throw off the speedometer and odometer slightly. |
| Flyinlow |
Aug 28 2026, 01:56 PM
| fixer34 |
Aug 28 2026, 06:53 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,466 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest
How much are we talking when you say 'faster'? Have you checked over a known distance of 10-20 miles?
Stock 'upgrade' was 185/70-15, so your tires are a little bit smaller in diameter. That means you don't actually go as far for a given number of revolutions, but since the odometer is geared based on revolutions of the cable, it will read 'high'. |
Lo-Fi Version | Time is now: 28th August 2026 - 08:44 PM |
