| bajafreaks |
Aug 23 2026, 04:54 PM
Member ![]() ![]() Group: Members Posts: 154 Joined: 7-February 14 From: Gardnerville, Nevada Member No.: 16,969 Region Association: Northern California |
I know torsion bars are extremely important piece to the front end puzzle.
Are these too far gone? Two pics are exactly as removed, the other two are brushed up with a wire wheel. The ware is only on one end of each one, and there is a slight "ridge" i can feel. Thanks ![]() [attachmentid=982572] ![]() |
Aug 23 2026, 04:57 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,876 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
Although I’m sure people drive around with similar or worse, I would not reuse them. If one does go bad at the wrong time, it could really spoil your day.
Basic rule of thumb is if there’s any wear, corrosion or grooving, they should be replaced. |
| jim_hoyland |
Aug 23 2026, 05:26 PM
Get that VIN ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,122 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California
When a torsion bar needs replacement, does the steering feel change ?
Aug 23 2026, 06:10 PM
When a torsion bar needs replacement, does the steering feel change ? No. An old torsion bar may let the car settle a bit (it’s just a spring) but nothing really changes in feel unless they break, which can happen while moving or standing still, since they are always under tension. |
| bkrantz |
Aug 23 2026, 07:47 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,767 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains
Remember, in torsion bars (and other springs) the highest stress levels are just below the outer surface. Damage there is more critical.
Lo-Fi Version | Time is now: 24th August 2026 - 01:05 AM |
