> Battery Isolator: Any benefit?, What's the nominal "off" current?
LikesSummer
post Aug 20 2026, 01:23 PM
Region Association: Canada
So assuming one has an unmodified car, what's the key-out, "off" current on these? I've got a 72 4 which doesn't even have a radio. I could certainly go through the wiring diagrams and determine this for myself if this is potentially anything other than zero, but there's a good chance I'll miss something quirky, so I'm asking the experts.
If turning the car off brings the background current to zero, then there's no need for an isolator obviously.
flipb
post Aug 20 2026, 02:28 PM
Cars with appearance group have a clock. Most of them quit working decades ago but the ones that work would have some draw. I also noticed that my (presumably dealer-installed) radio isn't switched by the car's ignition so I have to make sure it's turned off.
Ninja
post Aug 20 2026, 02:46 PM
Without a radio (with a memory circuit-modern) or a clock it should be zero.
Easy way to determine.
Pull negative cable off of battery, attach a test light or DVOM (amps) between the cable and terminal and you'll have your answer.
post Aug 20 2026, 03:17 PM
my 1975 example with the appearance group always has a small spark when I connect/disconnect the battery. I have never measured, but also never had an issue with a dead battery.
jvmarino
post Aug 20 2026, 09:31 PM
For my older cars I have added disconnect switches on the battery ground post of each car. For one of them (not the 914) it was to stop a slow battery drain. I decided to do the same for the others after reading a story of a garage fire started from a shorted wire. Guy lost entire garage and almost the house. Seemed a good idea to use the disconnect to help prevent the same thing on one of my cars with wiring 50 years old or older.
LikesSummer
post Aug 20 2026, 11:07 PM
What is this technology you refer to as "CLOCK"?
I have none of that, so I am going to assume that the current drain on a machine like mine is going to be zero.
You're right; the VOM is the best way to assess this, but first one needs to know what one should expect! If I am to expect zero and a get zero, good. If I get something else, not so good. I am, for kicks, going to hook up my meter.
I hadn't considered the fire angle actually. I have an isolator on the positive side of one of my other, more daily driver cars, since it is computerized but still sits for long periods. It's a blade-style that I got here in Canada from Princess Auto.
What are folks who are installing these using (I'm curious) and why?
Thanks for all the great info!
- Lo-Fi Version Time is now: 20th August 2026 - 11:41 PM
