| DennisV |
Aug 18 2026, 07:40 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,005 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California
Is this the correct bolt to secure the flapper box to the heat exchanger on a 914-6? Part number 901-211-631-00. Appears to be NLA. Paired with square nut.
It is what I removed from a pair of used flapper boxes I bought. I tried installing it on a new Dansk flapper / heat exchanger and it appears too short. Even if I try various clamps to compress the flange and close the distance. ![]() ![]() |
| Puebloswatcop |
Aug 18 2026, 07:51 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,724 Joined: 27-December 14 From: Mineola, Texas Member No.: 18,258 Region Association: Southwest Region |
Dennis, I tried looking it up in the PET and other resources and it doesn't give a length. It sould be an M6 bolt although that is an assuption based on the fact that it shows the nut on it is M-6. Sorry its not much help, but you can at least check if its M6. if the one you have doesn't meet that spec, then you'll know its not right.
| bdstone914 |
Aug 19 2026, 03:29 AM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,353 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Is this the correct bolt to secure the flapper box to the heat exchanger on a 914-6? Part number 901-211-631-00. Appears to be NLA. Paired with square nut. It is what I removed from a pair of used flapper boxes I bought. I tried installing it on a new Dansk flapper / heat exchanger and it appears too short. Even if I try various clamps to compress the flange and close the distance. ![]() ![]() I assumed the 4 and 6 flappers took the same bolt. But thevpart number does start with 901. I can check if a 4 flapper fits a 6 exchanger. Im sure i have those bolts to check. Im betting it is the Dansk flapper that is the problem. |
Lo-Fi Version | Time is now: 19th August 2026 - 07:43 AM |
