3 Pages V  1 2 3 >
> Picked up a 73 2.0 project, Future 6 conversion
Luke M
post Aug 14 2026, 07:08 PM
I added another 914 to my collection. It's not that I don't have enough work to do on my 914-6 but this is more of a father and son project. I found this 73 2.0 appearance package is the southern tier of NY. I worked out a deal with the p/o and I picked it up today. I believe the org 2.0 engine was sold to a person in PA. I didn't care too much about that as I'm going to be installing a 6 into it. The car is pretty much complete other then the missing engine. It needs work in the usual spots but otherwise the chassis is in good shape. I took a few quick shots when I got it home but I'll take a few more on Sat.
post Aug 14 2026, 08:22 PM
rick 918-S
post Aug 15 2026, 03:54 AM
Hey nice rack! -Celette
post Aug 15 2026, 06:42 AM
money shot(s)
another /6 project?
aharder
post Aug 15 2026, 06:49 AM
Luke M
post Aug 15 2026, 06:17 PM
I took a quick look at the 73 2.0 today. The right engine shelve needs to be replaced as there's lots of pin holes and rust there. The hell hole looks ok but I need to really get in there and dig around. Both jack points are bad and the p/o cut them out. Front and rear trunks look good. The floor pans are in pretty great shape minus a few dents from someone jacking the chassis up. The interior is in pretty good shape and just needs a cleanup. The seats will need some work. Each fender and q-panel has an issue so it's a good candidate for a set of steel flares. The good news is the car came with some of new RD metal for the repairs.
The plan for this one is a 6 conversion, 5 lug setup, steel flares, and a paint job back to the org silver paint.
All of the 4 lug stuff is going up for sale, wheels/tires, and anything 2.0 4 engine stuff that's left in the engine bay.
Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image
post Aug 16 2026, 01:42 AM
Are those ..No Crash Beam, Late window mechanism, Doors??
post Aug 16 2026, 01:43 AM
(IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/aktion035.gif)
post Aug 16 2026, 05:16 AM
“The plan for this one is a 6 conversion, 5 lug setup, steel flares, and a paint job back to the org silver paint.”
$100k decision?
Luke M
post Aug 16 2026, 06:33 AM
QUOTE(mepstein @ Aug 16 2026, 04:16 AM) *
$100k decision?
I have 90 to 95% of the parts needed to convert this one to a 6.
I have the front and rear 5 lug suspension, RD steel flares, wheels/tires, 2.7 RS and a rebuilt side shift trans, oil tank/lines, motor mount, and gauges. Mainly what I'm missing is some new misc RD sheet metal, steel fuel lines, new rubber seals, bushings, and some miscellaneous hardware. The body and paint work will be my biggest expense. Sounds easy enough doesn't it... (IMG:style_emoticons/default/laugh.gif)
And no I'm not taking any parts away from my 6 build to supply this one.
All of my other 6 parts are in their own bins awaiting for the day to go back on.
These are just parts that I've purchased and stashed away because I wanted to build a 914-6 conv with my son. I just had to find the right 914 to buy first. Compared to some of the other 914's that I've looked at this one believe it or not isn't in bad shape. I can easily deal with the metal work that needs to be done on this one.
Luke M
post Aug 16 2026, 06:38 AM
QUOTE(sixnotfour @ Aug 16 2026, 12:43 AM) *
I'll take a look and report back. I just jammed some cardboard between the windows and door frame so the glass wouldn't get damaged in transport.
post Aug 16 2026, 07:22 AM
QUOTE(Luke M @ Aug 16 2026, 08:33 AM) *
$100k decision?
I’m in no way saying it’s a bad decision. I think it’s great that you will restore and modify that car into something special.
Luke M
post Aug 16 2026, 02:58 PM
QUOTE(mepstein @ Aug 16 2026, 06:22 AM) *
$100k decision?
Hi Mark, I didn't take it in a bad way. I know it's crazy expensive to do a conversion now a days. It seams the cost of parts have gone through the roof. I've always wanted to do another conversion. I've been lucky enough to be able to buy and stash away most of the parts needed.
I've also checked the doors and they are the late style window mechanism without the later crash bars. I hope they will be good enough to use.
post Aug 17 2026, 01:15 PM
hate to ask, but this will increase your collection to _? or is it double digits
Luke M
post Aug 17 2026, 01:23 PM
QUOTE(930cabman @ Aug 17 2026, 12:15 PM) *
Hi John,
Three total Porsche vehicles. Two 914's and a Cayenne S.
If you're ever out my way swing by, you have my number. (IMG:style_emoticons/default/beerchug.gif)
I started cleaning out the interior today. I hate when people butcher the chassis to make things fit. I'd have to take a good pic of what I found today.
I need to check the passenger side to see if it has the same issues.
post Aug 17 2026, 02:59 PM
QUOTE(Luke M @ Aug 17 2026, 01:23 PM) *
Hi John,
Thank you for the invite, I am planning a trip to visit Phil at Batavia Starter soon, please PM your address. I will let you know when I will be heading out
Luke M
post Aug 19 2026, 05:35 PM
We started the disassembly portion of this build. The interior is about done. The dash and harness needs to be removed yet. I found some sketchy stuff done to the wire harness so that'll have to be addressed. The sound pad/tar paper or whatever it's called now a days needs to be removed from the floor pan. That's a special job set aside for my son to get done. Front trunk is about done too. Fuel tank, fresh air box, and wiper motor is out. Still need to get the headlight assemblies out and move the harness back to the bulkhead for removal. Rear trunk is done. The engine bay is getting there. I have a few more items to remove. I took a look at the hell hole and it needs a little work. The right engine shelve will need to be replaced but that's easy enough to do. I'll see what tomorrows schedule looks like and hopefully get some of these items above taken care of. I also posted a pic behind the speaker grills. Both sides look like this.. (IMG:style_emoticons/default/blink.gif)
I do not know why people butcher cars like this.
bkrantz
post Aug 19 2026, 08:14 PM
Looks like buying a 914 with the sills already cut open is a good way to judge rust problems.
Luke M
post Aug 21 2026, 05:44 AM
We got the 73 pretty much stripped minus the suspension. We found a few old mice nests while removing the wire harness. Next we will roll it outside and pressure wash the heck out of it. Once that's done it's time to brace it and get it onto the rotisserie. Then the suspension will come off. So far we aren't finding anything major to repair minus the jack points and drivers door post. The headlight buckets, trunk channels, floor pans, and trunk floors all look too darn good to be true. This is a decent chassis for being 53 years old. It must have been a garage kept 914 from what I'm seeing. The wire harness has a few problems and will need some wires replaced thanks to the mice damage... (IMG:style_emoticons/default/chowtime.gif) ....
Time to cleanup the shop and get parts labeled and into bins.
post Aug 21 2026, 06:01 AM
Clean car by most standards. (IMG:style_emoticons/default/popcorn[1].gif)
3 Pages V  1 2 3 >
18 User(s) are reading this topic (18 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 2nd October 2026 - 06:46 PM
