| ctc911ctc |
Aug 6 2026, 11:01 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,356 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States
70, 914-6 All stock, original carbs
All Teeners, In my last Buccee post i took the car for a drive and the carbs were not right though I did balance them using the Least Lean method. I will leave out that when I dropped the linkage to the carbs that the throttle cable got wrapped around the clutch assembly and what happened next (IMG:style_emoticons/default/mad.gif) I have been driving the car for the past few days and then I remembered Richard Towles voice telling me it is always dwell, start with the Dwell Grasshopper. So i went to set the dwell FORGETTING that the Ignition BOX makes dwell angle less relevant (time to charge,etc). BUT, i set it anyway! Dwell in a 6 is done with the Distro OUT of the car Where is the darn collar bolt located, grrr Is it an 8 or a 10......sigh its a 10, of course I went in with an 8 pull, Pull, PULL........10 minutes later.......pull, Pull, PULL and POP Dang, hitting my knuckles when the distro released was painful Distro on bench, reset (was a tiny bit tight) the gap Distro back into the car Where is that hole...........common question from me...... (IMG:style_emoticons/default/dry.gif) Put the distro back in PUSH, PUSH, ah in......pointing at the wrong angle Remove distro again - PULLING FOR 10 min.......dang got the other knuckle. Put the distro back in- angle is good, comutator pointing right at the fan housing...ahh RATS, did not set TDC prior to removing (IMG:style_emoticons/default/blink.gif) Removed the distro again. (IMG:style_emoticons/default/sad.gif) Set car in 5th Rock forward, never reverse ah, there it is TDC is white, 35deg is RED (one smart thing I did when Mark sold me the Flywheel - THANK MARK!) Get the distro into the hole - easier to find with practice (IMG:style_emoticons/default/dry.gif) get timing light ready start the car grind...grind...grind...nothing Check Electrics Is the power on the points - yes Does the ignition box create spark - pull plug rock the advance spring - SPARK Great Check a dozen things - LIGHT APPEARS OVER MY MARBLE HEAD 180degrees out of phase (IMG:style_emoticons/default/sad.gif) OK reset TDC, commutator pointing 180@ out of phase - THE REAL TDC has arrived PULLLLLLLLLLL out the distro (time 5 and counting) Rotate Put back in set the distro assembly pointed to the fan Start the car VrrrRoom! first try. If you are still here, I was trying to get rid of the bucking when this all began. Still bucks (IMG:style_emoticons/default/hissyfit.gif) QUESTION: I will retune the carbs (Stock everything on the carbs) but would you focus on other electric things - wires (new from Pelican), distro is rebuilt (there is a post about it) all new components on distro. OR For correct advance testing the 6000RPM advance must be at 35deg....if you adjust this are we not changing the idle advance too? Might the springs be wrong for the timing to be correct at 3000 RPM - bucking is at 2K, 3k and 4k when there is no load either positive or negative. THANKS in Advance! 35degrees! CTC |
Lo-Fi Version | Time is now: 6th August 2026 - 12:12 PM |
