> Horn Ring Contacts, Grease or Not?
NARP74
post Aug 5 2026, 08:44 AM
While replacing my turn signal I noticed some old dried grease on both sides of the horn contacts. What should I replace it with? Does it need to be conductive?
DennisV
post Aug 5 2026, 10:05 AM
QUOTE(NARP74 @ Aug 5 2026, 07:44 AM) *
The factory manual says "Lightly grease contact ring for signal horn. Use electrical contact grease."
What they fail to clarify is, do they mean conductive or not. I have seen arguments both for and against conductive grease as well as dielectric grease. (IMG:style_emoticons/default/confused24.gif)
GregAmy
post Aug 5 2026, 10:48 AM
With a proper mechanical electrical contact, non-conductive dielectric grease is the proper use. Using conductive grease(?) will lead to spurious undesired connections.
If dielectric grease stops the electrical connection from functioning then you do not have a proper contact.
18 User(s) are reading this topic (17 Guests and 0 Anonymous Users)
1 Members: DennisV
- Lo-Fi Version Time is now: 5th August 2026 - 12:16 PM
