> Side-shift Conversion Assembly Question, Center-Console Rod Clocking
Nein For Teens
post Aug 1 2026, 11:20 PM
Hi Teener's. I'm converting a tail-shift transmission to side shifting. I have all the parts for the conversion . . . I think :-) My concern is how to clock the center-console rod into the bottom of the shifter so that the u-joint and the rear shift rod end up where they are meant to be? Is there a simply procedure to accomplish this? Both the engine and the trans are out of the car. Just FYI: I'm just about to install one of Chris Foley's firewall bushing kits. All other bushings will be urethane of bronze. Thanks in advance for whatever help is available. Chris
Nein For Teens
post Aug 1 2026, 11:23 PM
D'oh! Clearly, I'm new at this. I should have posted this in the tech section. How can I migrate it over there?
dug
post Aug 2 2026, 12:18 AM
914-6 conv in progress
Put the trans selector in 2nd.
Then with the shift lever held gently against the first/rev spring, not compressing it, push the shifter forward so it slides onto the tunnel rod.
- Lo-Fi Version Time is now: 2nd August 2026 - 05:37 AM
