| davep |
Jul 23 2026, 06:52 PM
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,368 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
So the coolant level warning pops up, and I go to check the tank level. No info to be found there. So on to the cap. Waited days, and it is cold. Turn the cap about 30 deg and the tab on the bottom rim hits a stop on the neck; and it is game over: it will not turn or come off. There has to be a trick, but I cannot figure it out.
Some Benz forums mention cutting off the tab or just using brute force, but I see potential disaster with those methods. If it was turned into place it should come off with a minimum of fuss. |
| wonkipop |
Jul 24 2026, 01:04 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,626 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille
So the coolant level warning pops up, and I go to check the tank level. No info to be found there. So on to the cap. Waited days, and it is cold. Turn the cap about 30 deg and the tab on the bottom rim hits a stop on the neck; and it is game over: it will not turn or come off. There has to be a trick, but I cannot figure it out. Some Benz forums mention cutting off the tab or just using brute force, but I see potential disaster with those methods. If it was turned into place it should come off with a minimum of fuss. might be a sign the cap has failed. when they fail the system loses pressure. possible reason for coolant level warning message. buy a new cap. get the old one off with a wrench if you can't force it by hand. if you are nervous about that take it into the dealer. those caps are designed to release excess pressure and if they break they won't seal the system properly. could mean your coolant now has a lower boiling point. the failure of the cap is probably the reason it won't make the turns past the locking tab. |
Lo-Fi Version | Time is now: 24th July 2026 - 11:15 PM |
