| TJB/914 |
Jul 20 2026, 10:51 AM
Mid-Engn. ![]() ![]() ![]() ![]() Group: Members Posts: 4,502 Joined: 24-February 03 From: Plymouth & Petoskey, MI Member No.: 346 Region Association: Upper MidWest
Took my 914 out for a cruise yesterday & had shifting problems on the highway with no 4th or 5th gear shifts. In the garage at startup gear shifting (wobbly) was loose into all gears. On the highway 1st. 2nd & 3rd was ok but nothing into 4th. or 5th.? Need advice where to look & start for repairs. 914's are so low, getting under the 914 has issues for inspections as I get older (IMG:style_emoticons/default/headbang.gif) Tom, Looking for 914 repair shops in the Petoskey MI area is difficult. |
TJB/914 Gears not shifting into 4th & 5th + other issues into 1-2-3 Jul 20 2026, 10:51 AM
brant Start with bushings and the shifter linkage set sc... Jul 20 2026, 11:01 AM
friethmiller I had this same problem where it just starts happe... Jul 20 2026, 11:22 AM
brant Start with bushings and the shifter linkage set sc... Jul 20 2026, 12:17 PM
TJB/914
Start with bushings and the shifter linkage set s... Jul 20 2026, 12:36 PM
FlacaProductions pull back the boot on the engine side of the firew... Jul 20 2026, 03:03 PM
windforfun
pull back the boot on the engine side of the fire... Jul 20 2026, 03:07 PM
NARP74 I built a set of wheel cradles out of scrap wood f... Jul 20 2026, 03:31 PM
Luke M
Took my 914 out for a cruise yesterday & had ... Jul 20 2026, 03:32 PM
emerygt350 I have a couple cheap drive on AutoZone ramps. Th... Jul 20 2026, 05:35 PM![]() ![]() |
Lo-Fi Version | Time is now: 20th July 2026 - 11:17 PM |
