2 Pages V  1 2 >
> FS Reproduction 914-6 style accelerator linkage sets, $225 early group buy or $250 later
post Jul 17 2026, 10:25 PM
I have the first prototype parts for the 914-6 style accelerator cable bracket, bell crank and linkage pull rod.
I redesigned the pull rod and bell crank. The cable support support bracket is 3D printed in stainless steel for increased strenght and rust prevension.
The bell crank and pull rod use metric ball sockets wirh a safety wire clip and dust cover to prevent dirt from entering the socket.
The pull rod uses two ball sockets unlike the original rod which uses a wire loop that wears.
All parts will be yellow zinc plated.
The bell crank is made with sloted holes to adjust the throttle modulation. The pull rod lenght is adjustable as it is a hollow tube connecting two ball sockets with all thread.
The set will include an original pivot post with plastic bushings.
The set requires an intermediate plate with the threaded boss for the bell crank. These were used on tail shift and 914-6 transmissions.
Group buy price now is $225. It will increase to $250 when i have full production in 2-3 weeks.
At this time i only have 10 accelerator brackets but can get more in about two weeks.
I prefer payment by Zelle or check image.
Shipping at cost by UPS ground.
I used a piece of all thread in the pictures in place of an actual accelerator cable.
post Jul 18 2026, 06:26 AM
Real world solutions for hard to find parts. Like the adjustability for FINE tuning. (IMG:style_emoticons/default/smilie_pokal.gif)
post Jul 18 2026, 08:11 AM
@Luke M
@sixaddict
@Montreal914
@racer914
@scrz914
@markhoward
@Nate W
@live free & drive
post Jul 18 2026, 08:13 AM
@mate914
@rick 918-S
@mepstein
@pencap914
@yellowporky
@Niklas
@Robarabian
@mb911
post Jul 18 2026, 08:15 AM
@GTS
@Root_Werks
@Graydingo
scrz914
post Jul 18 2026, 09:15 AM
Nice Bruce. Stainless steel and adjustability are a nice touch. Since the rod from the crank to the engine is a hollow tube, I’m assuming it’s a straight shot? No curve for the axle?
post Jul 18 2026, 10:21 AM
QUOTE(scrz914 @ Jul 18 2026, 08:15 AM) *
Correct. Straight tube. The curve is not needed to clear the axle. It was to clear the vacuum pot for the beloved sportomatic.
I could gave rhem made with the curve at added cost if someone wanted a original look. But the part is not original so why?
post Jul 18 2026, 11:03 AM
I’m in for a set. Thanks
Jett
post Jul 18 2026, 06:25 PM
I’m in for a set please
mate914
post Jul 19 2026, 07:11 AM
Matt
I'm in for a set also.
racer914
post Jul 19 2026, 07:13 AM
I will take a set
post Jul 19 2026, 07:44 AM
QUOTE(racer914 @ Jul 19 2026, 06:13 AM) *
I will take a set
PM send. I need your full address too.
Thanks
rick 918-S
post Jul 19 2026, 09:46 AM
Hey nice rack! -Celette
Thanks for the notification Bruce. I am in if I don't win the bid on that 6.
NARP74
post Jul 20 2026, 08:39 PM
What is everyone currently using if they don't have this?
I would get one but I am missing parts above the engine tins to make it work.
DAPO kludge solution.
post Jul 20 2026, 11:36 PM
@NARP74
' date='Jul 20 2026, 07:39 PM' post='3265789']
[/quote]
I dont know what most people are doing for these parts. Patric Motorsports has a couple more expensive systems.
Some have modified the 911 bell cranks. The early 911 rod works.
I wanted to make a better and more affordable solution.
I have some of the linkage above the tin. Im looking at remaking some of those parts.
I have several cross bars. I can sell you one of those.
PMO is seĺling a kit for some of those partd
mb911
post Jul 21 2026, 04:43 AM
Bruce,
I am in for a set and would also like to put on my website
NARP74
post Jul 21 2026, 08:26 AM
What cable does this use?
914Wes
post Jul 21 2026, 09:09 AM
QUOTE(NARP74 @ Jul 21 2026, 07:26 AM) *
It is setup for the stock 914-6 cable. Part number 91442306602
914 parts diagram - Ill. 702-00 - Accelerator pedal
Interactive version (click parts for prices + availability): https://914catalog.com/#i=702-00&p=7
(IMG:http://www.914world.com/bbs2/uploads_offsite/img.914catalog.com-26388-1784646543.1.png)
roundtwo
post Jul 21 2026, 11:14 AM
@bdstone914
Hi Bruce,
I have a 1973 with side shift 3.0 liter six with PMOs.
Does the kit contain everything I need to convert from the basic cable pull right to the carbs?
Can you describe what this is? :"The set requires an intermediate plate with the threaded boss for the bell crank."
If so, I'd like to buy the set.
I can send you pics of my current set up if needed.
Thanks, Todd
Aerostatwv
post Jul 21 2026, 04:41 PM
Hello, Bruce!
Please put me down for a set as well.
Thanks!
2 Pages V  1 2 >
- Lo-Fi Version Time is now: 31st October 2026 - 06:00 AM
