| Jezibel |
Jul 9 2026, 03:08 PM
Das Echte POORSCHE Fahrer ![]() ![]() Group: Members Posts: 68 Joined: 21-January 24 From: Northern California Member No.: 27,868 Region Association: Northern California |
Hi folks. I need to find a 914-4 Combi headlight 4-pin relay, Porsche 111-941-583A, which everyone tells me simply do not exist any more (except as perhaps salvaged 'used' parts). Auto Atlanta, SMC, 914 Rubber, et al, all offer the 5-pin relay (111-941-583) that fits '75/'76 914s as a replacement, which of course the earlier 4-pin cars they are not compatible with.
This is a real stumper and I know that many of you may have likely encountered this frustration in the past. What I need to know is 1) Does anyone still sell the 4-pin relays or is everyone selling the incompatible 5-pin relays? 2) Are they available anywhere other than possibly via salvaged units from junk yards? You'd think that there would still be some of these floating around in Germany or England, but so far I've had no luck pursuing that option. I can't believe that some bright person hasn't figured out that this is a BIG problem that cries for redress. I know that the 111-941-583A relay rarely fails, but if they do, a replacement is the only option. I am also aware of the fact that a similar appearing relay made by VW starting with 381 that is a 4-pin relay appears as if it might be the same 4-pin headlight 'Combi' relay, but have no confirmation of that. I know there was a thread on this some time ago but don't know how to all it up. At any rate, even there they had no ready solutions to this perplexing problem. Any helpfull insights would be most appreciated! I also hear that some Chinese-made 111-941-583 relays have been 'bridged' so as to work, but I'm not well informed about that and it sounds rather precarious to me to use one (if they are even offered anywhere). |
| porschetub |
Jul 9 2026, 08:01 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,151 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Hi folks. I need to find a 914-4 Combi headlight 4-pin relay, Porsche 111-941-583A, which everyone tells me simply do not exist any more (except as perhaps salvaged 'used' parts). Auto Atlanta, SMC, 914 Rubber, et al, all offer the 5-pin relay (111-941-583) that fits '75/'76 914s as a replacement, which of course the earlier 4-pin cars they are not compatible with. This is a real stumper and I know that many of you may have likely encountered this frustration in the past. What I need to know is 1) Does anyone still sell the 4-pin relays or is everyone selling the incompatible 5-pin relays? 2) Are they available anywhere other than possibly via salvaged units from junk yards? You'd think that there would still be some of these floating around in Germany or England, but so far I've had no luck pursuing that option. I can't believe that some bright person hasn't figured out that this is a BIG problem that cries for redress. I know that the 111-941-583A relay rarely fails, but if they do, a replacement is the only option. I am also aware of the fact that a similar appearing relay made by VW starting with 381 that is a 4-pin relay appears as if it might be the same 4-pin headlight 'Combi' relay, but have no confirmation of that. I know there was a thread on this some time ago but don't know how to all it up. At any rate, even there they had no ready solutions to this perplexing problem. Any helpfull insights would be most appreciated! I also hear that some Chinese-made 111-941-583 relays have been 'bridged' so as to work, but I'm not well informed about that and it sounds rather precarious to me to use one (if they are even offered anywhere). As you mentioned these relays don't fail often which appears they don't do ,zip over to the WTB section and get a good used one....problem solved . Cheers. |
| 914Sixer |
Jul 10 2026, 06:08 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,534 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
EBAY
Attached thumbnail(s) |
| sixnotfour |
Jul 10 2026, 06:50 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,301 Joined: 12-September 04 Member No.: 2,744 Region Association: NineFourteenerVille
If you cant waite or want to update,,,run a jumper wire....
| fixer34 |
Jul 10 2026, 03:07 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,463 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest
| fixer34 |
Jul 10 2026, 03:13 PM
If yours has the metal 'can', carefully bend back the tabs over the phenolic board and lift it off. See if there is a latch mechanism similar to the above picture.
If it looks the same, I'll send you the one I have to try. Maybe also try manually moving the relay arm and cleaning the contacts on yours. |
| ejm |
Jul 10 2026, 04:52 PM
I can see the light at the end of the tunnel ![]() ![]() ![]() ![]() Group: Members Posts: 2,718 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
@Jezibel The relay that you are asking about is the hi/low beam relay.
It has nothing to do with the headlights not retracting. Assuming the headlights go up when you turn them on but not down when off the problem is most likely the headlight switch. |
| porschetub |
Jul 10 2026, 10:27 PM
(IMG:style_emoticons/default/agree.gif) ,check the wiring up to the switch also ,not uncommon to find "chop" jobs or damage from age or overload .
cheers. |
| Jezibel |
Jul 12 2026, 01:08 PM
If yours has the metal 'can', carefully bend back the tabs over the phenolic board and lift it off. See if there is a latch mechanism similar to the above picture. If it looks the same, I'll send you the one I have to try. Maybe also try manually moving the relay arm and cleaning the contacts on yours. Thanks, FIXER. I'll check it and we'll see what happens. -JEZIBEL |
| Jezibel |
Jul 12 2026, 01:09 PM
@Jezibel The relay that you are asking about is the hi/low beam relay. It has nothing to do with the headlights not retracting. Assuming the headlights go up when you turn them on but not down when off the problem is most likely the headlight switch. Thanks for that advice, EJM. I have a spare (73-76 type) MAIN LIGHTS switch, so I'll check that out, also. -JEZIBEL |
| Jezibel |
Jul 12 2026, 01:16 PM
(IMG:style_emoticons/default/agree.gif) ,check the wiring up to the switch also ,not uncommon to find "chop" jobs or damage from age or overload . cheers. Thanks for that advice. All helpful suggestions. By the way, George (at AUTO ATLANTA) tells me that he addresses this particular problem on pages 81-86 of his TECH TIPS 700 technical guide to the 914. I guess I should have known that he would have already considered this specific matter in that book (whoda thunkit?!). (IMG:style_emoticons/default/smilie_pokal.gif) |
| Jezibel |
Jul 12 2026, 01:20 PM
Yep. The 'Latching-type' headlight low/high beam relay. 111-941-583A. I've got a spare now, so I'll check the MAIN LIGHTS switch first, then the Latching-Relay. The fuses all seem to be good, so it's gotta be one or the other of these things, I reckon. -JEZIBEL |
| Jezibel |
Jul 16 2026, 12:15 PM
[/quote][/size] ------------------------------------- OK. Replaced the 'Combi-relay' with a used (but supposedly serviceable) 111-941-583A unit. Also replaced all three of the 5-pin round relays on the fuse/relay board with non-German (supposedly identical) units (which I notice have pins that are a 1/4 inch longer than the German OEM type type). Checked all the fuses. Replaced the main lights switch with the correct 11-pin "late model" 914 switch (a 'used' spare). Patted myself on the back, rebolted the fuse/relay panel to the under dash. Made sure the "new" main lights switch was hooked up properly, and reattached the battery ground. Switched on the ignition and tried the main lights. This time, the light buckets popped up (as they should), but no illumination at all in them. Brake lights, turn signals and hazard lights all operated properly, but no main head or tail lights at all. And the buckets still refuse to retract. ARRRRRRRRRRGH! (IMG:style_emoticons/default/headbang.gif) I've just about run out of answers completely. Any Harry Potter wizards lurking around out there who can grant wishes? |
| Jezibel |
Jul 16 2026, 01:53 PM
[quote name='Jezibel' date='Jul 16 2026, 11:15 AM' post='3265277']
Yep. The 'Latching-type' headlight low/high beam relay. 111-941-583A. I've got a spare now, so I'll check the MAIN LIGHTS switch first, then the Latching-Relay. The fuses all seem to be good, so it's gotta be one or the other of these things, I reckon. -JEZIBEL [/quote][/size] ------------------------------------- OK. Replaced the 'Combi-relay' with a used (but supposedly serviceable) 111-941-583A unit. Also replaced all three of the 5-pin round relays on the fuse/relay board with non-German (supposedly identical) units (which I notice have pins that are a 1/4 inch longer than the German OEM type type). Checked all the fuses. Replaced the main lights switch with the correct 11-pin "late model" 914 switch (a 'used' spare). Patted myself on the back, rebolted the fuse/relay panel to the under dash. Made sure the "new" main lights switch was hooked up properly, and reattached the battery ground. Switched on the ignition and tried the main lights. This time, the light buckets popped up (as they should), but no illumination at all in them. Brake lights, turn signals and hazard lights all operated properly, but no main head or tail lights at all. And the buckets still refuse to retract. ARRRRRRRRRRGH! (IMG:style_emoticons/default/headbang.gif) I've just about run out of answers completely. Any Harry Potter wizards lurking around out there who can grant wishes? [/quote] |
| Jezibel |
Jul 16 2026, 02:04 PM
As long as we're discussing the 'Combi-relay' (high/low beam), I notice that there are two VW 111-941-583A Combi-relays that share the same part # and R-200-925 designation, but are listed as 1) 12VOLT brs 150W and 2) 12VOLT brs 100W. What's the logic behind this? The same part numbers but two different capacity ratings? Nothing like a further anomaly to confuse the issue and make trying to figure this all out logcally frustrating! -Jezibel
| Jezibel |
Jul 17 2026, 12:49 PM
As long as we're discussing the 'Combi-relay' (high/low beam), I notice that there are two VW 111-941-583A Combi-relays that share the same part # and R-200-925 designation, but are listed as 1) 12VOLT brs 150W and 2) 12VOLT brs 100W. What's the logic behind this? The same part numbers but two different capacity ratings? Nothing like a further anomaly to confuse the issue and make trying to figure this all out logcally frustrating! -Jezibel[ Tried a different Main Lights switch this AM and a different 11-941-583A 'Combi' switch and now the lights pop up and light (as they did originally), but they still refuse to retract. Since I've run out of possible answers and not being fully comfortable with a multimeter, I've booked an appointment with the only "local" Porsche service that still works on 914s (#&^%$*!) (IMG:style_emoticons/default/hissyfit.gif) , but they're pre-booked until the middle of August. Hard to believe I have to sit on my hands for a whole month before I can get my baby looked at by the experts! Meanwhile, I've lit several votive candles to Our Blessed Irish Saint of Permanent Porsche Troubles [color=#003300](Saint Bridgit of the Busy Knickers) and am hoping for a miracle...but my dues in the Eager Beaver Knights of Perpetual Tumescence have expired, so I'm not very optimistic... -Jezibel (IMG:style_emoticons/default/pray.gif) |
Lo-Fi Version | Time is now: 7th August 2026 - 06:56 PM |
