> expansion/evaporation tank. Dents on top, an easy fix?, Compressed air? Tanks in advance
post Jun 30 2026, 07:52 AM
They are so minor, if I could get my hand in there. I'm looking
for a possible easy fix to smooth these out a bit. The bottom is beautiful, doesn't even need paint.
friethmiller
post Jun 30 2026, 08:20 AM
You'd need some PDR tools to push from inside the tank, I'd think.
post Jun 30 2026, 08:35 AM
QUOTE(friethmiller @ Jun 30 2026, 07:20 AM) *
So drill a hole from the bottom to get the tool in. That is a good idea.
friethmiller
post Jun 30 2026, 09:18 AM
QUOTE(Shivers @ Jun 30 2026, 09:35 AM) *
Well, it may not be a good idea. (IMG:style_emoticons/default/confused24.gif) You could cut a small rectangle out of the bottom, fix the dent, and weld it closed. However, being that it is a vapor/gas overflow container... welding might not be the best idea. Others might be able to chime in.
post Jun 30 2026, 11:20 AM
QUOTE(friethmiller @ Jun 30 2026, 08:18 AM) *
Hahaha, an explosion, that’s just what I need. Maybe I should just fill it with some body filler. (IMG:style_emoticons/default/sad.gif)
post Jun 30 2026, 11:31 AM
QUOTE(Shivers @ Jun 30 2026, 10:20 AM) *
I know nothing about the paintless dent pulling and the big dent is right on the crease.
post Jun 30 2026, 01:02 PM
QUOTE(Shivers @ Jun 30 2026, 01:20 PM) *
This (IMG:style_emoticons/default/agree.gif)
Or find better part - not a rare part by any stretch
JeffBowlsby
post Jun 30 2026, 01:39 PM
Most are dented or oil canned (thin metal).
I have thot about pressurizing them with air thinking that may sufficiently pop out the waves. Perhaps additionally persuading them with externally-applied heat or a roller. The fabricators may want to weld rods onto them pull them out, but that is delicate work on thin metal.
6 User(s) are reading this topic (4 Guests and 0 Anonymous Users)
2 Members: aturboman, Craigers17
- Lo-Fi Version Time is now: 30th June 2026 - 03:58 PM
