> Weber woes, Please save me from insanity
wbgoggans
post Jun 23 2026, 11:18 AM
I’m at my wits’ end with my Webers.
They’re a pair of Spanish 44 IDFs. I’m running a fuel pressure regulator set at 2.5 psi, have set and verified float levels at least half a dozen times, and have rebuilt them again, and again, and then again for good measure.
Despite all of that, I’m still getting fuel in the crankcase.
For the life of me, I cannot figure out where the fuel is coming from. At this point, I’m so frustrated that I can’t tell up from down anymore, and I don’t feel like I’m following a logical diagnostic path.
Before I bite the bullet and spend $1,000 on a new set of Webers—or $400 on some Chinese knockoffs—would anyone be willing to take a look at these carbs? I’d be more than happy to pay shipping both ways and compensate you for your time if you can figure out what’s going on.
I’ve got a serious case of sunk-cost fallacy at this point, but more than anything I’d just love to understand what I’m missing so I can finally sleep at night.
For those about to suggest the basics: fuel pressure has been verified at 2.5 psi, float levels have been set and rechecked multiple times, the needle and seats have been inspected and replaced, and the problem persists. The fuel tank sits lower than the carburetors, so gravity feed should not be a factor.
Thanks in advance for any help or suggestions.
Osnabruck914
post Jun 23 2026, 12:38 PM
I’ve had real Webers, knock off Webers, and Solexes on different cars over the years. IMO nothing beats Dellortos. Spend your money on them, you won’t regret it.
Osnabruck914
post Jun 23 2026, 12:55 PM
I have been a Weber guy for several decades, always the Bologna variety.
Possible float chambers are leaking when the engine is shut off?
They have kicked my a** more than once, but being me I never give in
best of luck
DennisV
post Jun 23 2026, 02:04 PM
QUOTE(wbgoggans @ Jun 23 2026, 10:18 AM) *
How confident are you that the pressure regulator is accurate?
You could send them to Mike Pierce at Weber Carburetor Restoration.
Jack Standz
post Jun 23 2026, 02:26 PM
How do you know fuel is getting into the crankcase?
What are the symptoms?
Have you looked down the throats with the fuel pump on and seen fuel dribbling into the motor (and then the fuel is getting past the rings into the crankcase?)?
Maybe the float is set so far off that the needle/seat doesn't close and the bowl(s) overflows? What are the floats set at?
You would think that if raw fuel was getting into the cylinder from high pressure over powering the needle/seat, the motor would hydrolock. Not good and not really what you described.
There have been times where incorrect plumbing has caused a similar problem with cars we used to own. Had a Toyota Celica GT we bought with a motor so full of gasoline that the motor would not turn. Smelled terrible, like fuel (IMG:style_emoticons/default/smile.gif) . Drained the "oil" which was mostly gasoline, flushed with some fresh oil and she was fine.
Maybe fuel is coming in via an incorrect fuel line attached to a stuck PCV valve or something? Just guessing here. That's unusual for significant fuel to make it to the crankcase.
Ninja
post Jun 23 2026, 04:07 PM
What engine are you running these on?
What venturis are in the carbs?
Mains/airs/idles?
Those carbs are too big for a 9.0/1 mild cam 2.0L unless you're running it near redline (competition engine).
Excessive fuel in oil is one of the symptoms of improper size selection.
Now, those are perfect for a stroker engine above 2.2L.
Even with the big engine you will probably have to downsize the venturis over the stock ones that came with the carbs for a street application.
What condition is your engine in?
Chad911sc
post Jun 23 2026, 04:43 PM
I agree with Ninja.
My 2056 wouldn’t run correctly through the transitions in my Spanish Webers until I put the 28 vents back in it. And that’s on 40 Idfs. I did end up getting it tuned in nicely with some 30 vents, but it took a lot of trial and error to get there. 44’s are big for 2.0
wbgoggans
post Jun 23 2026, 04:44 PM
QUOTE(Chad911sc @ Jun 23 2026, 06:43 PM) *
I agree with Ninja.
A few more details to answer some of the questions:
My fuel pressure regulator and gauge are both brand new from Summit. Both have good reviews, so I’m reasonably confident that the pressure reading is accurate.
I know fuel is getting into the crankcase because the oil level is rising, the oil is noticeably diluted, and it smells strongly of gasoline. I’ve also placed blue shop towels between the carbs and manifolds overnight. When I return the next morning, there are noticeable fuel stains on the towels. This morning, I repeated the experiment with the fuel pump turned on, and the towels were soaked within five minutes.
My float level is currently set at just a hair over 10 mm.
As for jetting, I know the venturis are 28 mm and the idle jets are 55s. I believe the mains are 110s with 190 air correctors, although I don’t have my notes in front of me at the moment.
I’m aware that 44 IDFs are larger than ideal for a 1.7. However, from what I’ve been told, the 28 mm venturis should make them reasonably manageable. I’d certainly be interested in hearing others’ thoughts on that.
That said, I don’t believe my primary issue is simply that the engine is running rich. Fuel is literally leaking from somewhere even with the engine not running. If I turn on the fuel pump and let the car sit, fuel eventually finds its way out of the carburetors, down the manifolds, and into the engine.
post Jun 23 2026, 05:49 PM
Take carbs off car
Place on paper towel
Fill float bowl - leave top cover & float off
Determine where fuel is leaking from into the throttle bore:
Dripping out the idle circuit ?
Dripping out the main ?
Dripping out the accel pump nozzle ?
Weeping through the casting ?
post Jun 23 2026, 06:29 PM
QUOTE(Superhawk996 @ Jun 23 2026, 05:49 PM) *
Take carbs off car
(IMG:style_emoticons/default/agree.gif) quick simple easy to narrow the issue
1 Members: Jack Standz
- Lo-Fi Version Time is now: 23rd June 2026 - 07:17 PM
