> Engine harness question- heater fan power
roundtwo
post Jun 19 2026, 04:52 PM
Hello,
Swapping out the 2.0 l engine in my 1971 for another 2.0 l ...Has lower miles (35k) and documented build.
Both engines carbed
I see the engine harness in a bit different at the end that connects to fan blower.
Pic 1 is the from the existing engine that had the fan blower mounted. Has the two wire connector to plug into the fan plug...
Pic 2 is from the replacement engine. I only see a white wire that is spare. Could this be the fan power and then I use a common ground? In understand what the other wires in the pic connect to.
Thanks the help going forward
pic 1
pic 2
car
JeffBowlsby
post Jun 19 2026, 05:14 PM
Use the ignition harness in Pic 1 on your 1971 car, its correct for your set-up, with the fan mounted to the engine. The Pic 2 harness is for 1973-76 cars with the heater fan mounted to a stand on chassis.
JeffBowlsby
roundtwo
post Jun 19 2026, 08:07 PM
@JeffBowlsby
I knew you would know and was hoping you weren't on vacation!!!
Thanks Jeff
Assume all I have to do is disconnect both from the alternators?
JeffBowlsby
post Jun 19 2026, 08:56 PM
Alternator? The ignition harness connects to the relay board, not the Alternator.
You can find diagrams of the two harnesses on my harness website.
- Lo-Fi Version Time is now: 19th June 2026 - 10:01 PM
