> Convert back to D Jet Fuel Injection-, Wire harnessess- Injector Ground
young55961
post Jun 18 2026, 02:34 PM
I have a question about the ECU wiring harness.
There are three pairs of white wires with female spade terminals on the harness. I believe they are the ground wires for the fuel injectors, but I can't find where they are supposed to connect.
Should these wires be connected to the negative (-) terminal of the ignition coil?
If anyone has a photo showing the correct connection, I would really appreciate it. Thank you!
Posts in this topic
young55961   Convert back to D Jet Fuel Injection-   Jun 18 2026, 02:34 PM
brant   There was supposed to be a three prong connector o...   Jun 18 2026, 02:46 PM
JeffBowlsby   2 of the three pairs are injector grounds. The th...   Jun 18 2026, 02:46 PM
young55961   2 of the three pairs are injector grounds. The t...   Jun 18 2026, 02:52 PM
Ishley   Here is what you’re looking for in the yellow ci...   Jun 18 2026, 08:12 PM
young55961   Here is what you’re looking for in the yellow c...   Jun 19 2026, 10:54 AM
DC_neun_vierzehn   Here is what you’re looking for in the yellow c...   Jun 19 2026, 03:54 PM
young55961   [quote name='Ishley' post='3261972' date='Jun 18 ...   Jun 19 2026, 08:17 PM
Jack Standz   It's easy enough to get one. Here's one e...   Jun 19 2026, 03:44 PM
Ishley   Mine is a '72 1.7 that I rebuilt into a 2056. ...   Jun 19 2026, 04:25 PM
Dave_Darling   Mine is further back, right by the flywheel end of...   Jun 19 2026, 09:27 PM
DC_neun_vierzehn   Mine is further back, right by the flywheel end o...   Jun 22 2026, 05:27 AM
robkammer   Mine is right at the top of the case split at the ...   Jun 23 2026, 05:38 AM
friethmiller   :popcorn: Observing... learning. I'll be do...   Jun 23 2026, 07:33 AM
young55961   I'm trying to test-run my 1975 Porsche 914 2.0...   Nov 1 2026, 12:22 PM
GregAmy   From my Microsquirt build notes. T4-I .75 and .5m...   Nov 1 2026, 12:31 PM
Dave_Darling   I'm pretty sure that #31 should get grounded b...   Nov 1 2026, 07:04 PM
1 Members: young55961
- Lo-Fi Version Time is now: 1st November 2026 - 08:23 PM
