> Convert back to D Jet Fuel Injection-, MPS electric issues
young55961
post Jun 8 2026, 09:42 AM
Hi there,
I purchased a D jet kit a few years back thinking convert my dual carb back to fuel injection.
I begin to inspect the parts I received.
First the MPS.
1. Pressure is good holding at 15 PSI
2. Outer Terminal(7, 15) : 94
3. Inner Terminal(8, 10) : "OL".
What does the outer and inner terminal control ?
Can it be fix ?
Tks.
Replies(1 - 3)
JeffBowlsby
post Jun 8 2026, 11:11 AM
15 PSI is probably OK if it remains steady. A steady 18 PSI is recommended.
The inner two and outer two terminals are contacts for the two coils. You should see a resistance between the outer two terminals of around ~350 ohms. If not, the problem could simply be a bad internal coil connection or the coil may be defective. The back half of the MPS can be exchanged with a known good part, requires disassembly. I may have one to swap, but you will need to send me the MPS for the repair or swap.
young55961
post Jun 8 2026, 01:41 PM
QUOTE(JeffBowlsby @ Jun 8 2026, 12:11 PM) *
I want to know if a bad MPS can prevent the engine from firing up, or if it would only cause the engine to run too rich or too lean.
I want to put everything back together first to see if the engine will run before spending more money replacing components.
JeffBowlsby
post Jun 8 2026, 03:26 PM
The MPS is the primary sensor for Djet. Engine will not start or continue to run without it, but there are other conditions that also result in a no-start even with a perfect MPS.
1 Members: JeffBowlsby
- Lo-Fi Version Time is now: 8th June 2026 - 05:30 PM
