> FS: rear spring threaded collar system, used, $100 and you can have the 180lb springs if you want
mskala
post Jun 6 2026, 07:55 PM
R
See pics, but these sit on spot where the original perch would go, and allow for
basically infinite height adjustment and help with corner weighting.
$100 shipped in lower 48. 180lb springs are still good and you can have them or not,
your choice. These springs, like most of the higher rate ones, are shorter and will be
totally free to move if you jack up the car, so consider 'helper springs' or zip tying
things in place.
Thanks
Mark S.
Driver174
post Jun 7 2026, 03:55 AM
I’ll bite on those! PM to follow; thanks
5 User(s) are reading this topic (5 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 7th June 2026 - 04:11 AM
