| Freezin 914 |
Jun 1 2026, 03:57 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 938 Joined: 27-July 14 From: Wisconsin Member No.: 17,687 Region Association: Upper MidWest
Hey gang, I finally got around to resealing my rear glass. In the process, took off Targa bar trim pieces, when reinstalling the seat belt bolts there is a bit of play it can pivot front to back towards the glass.
Is this normal? I do not recall there being any play really. I torqued the bolts pretty tight…..I did take a picture of the orientation of pieces as they came apart, assembled the same way when reinstalling. |
Jun 1 2026, 04:01 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,610 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
Hey gang, I finally got around to resealing my rear glass. In the process, took off Targa bar trim pieces, when reinstalling the seat belt bolts there is a bit of play it can pivot front to back towards the glass. Is this normal? I do not recall there being any play really. I torqued the bolts pretty tight…..I did take a picture of the orientation of pieces as they came apart, assembled the same way when reinstalling. I believe those top hangers do have the ability to swing. Mine are very tight though |
Jun 1 2026, 05:15 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,726 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
If I recall correctly, the end of the belt is sandwiched between two nylon washers. So they won't get direct torque. The bolt would bottom out first and the belt can pivot a bit.
Lo-Fi Version | Time is now: 2nd June 2026 - 04:40 AM |
