| hndyhrr |
May 29 2026, 04:05 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 682 Joined: 1-September 13 From: central point,oregon Member No.: 16,332 Region Association: Pacific Northwest
Good afternoon.
I have a new Dansk gas tank (installed) for the pumpkin (1970 4 cyc). Got it installed and plumbed, ready to put evap chamber (I think that what it is called, goes around filler neck.) The damn thing won't fit. Seems brackets on tank are not right! I have attached a couple of pic. Any thoughts or ideas about what to do to get it installed? Thanks |
| hndyhrr |
May 29 2026, 04:07 PM
Good afternoon. I have a new Dansk gas tank (installed) for the pumpkin (1970 4 cyc). Got it installed and plumbed, ready to put evap chamber (I think that what it is called, goes around filler neck.) The damn thing won't fit. Seems brackets on tank are not right! I have attached a couple of pic. Any thoughts or ideas about what to do to get it installed? Thanks |
| rick 918-S |
May 29 2026, 04:10 PM
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,278 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region
Others may know more but I recall something about the flange height being taller than the original
| hndyhrr |
May 29 2026, 06:40 PM
I have read that some where on this forum.
My question is I guess is how the heck to fix it. I am not a metal fabricator or welder. I do have a friend that can help me just need to know what to do to it. Thanks |
| fiacra |
May 29 2026, 07:19 PM
Person.Woman.Man.Camera.TV. = MCI ![]() ![]() ![]() Group: Members Posts: 734 Joined: 1-March 19 From: East Bay Region - California Member No.: 22,920 Region Association: Northern California
These threads might be helpful:
http://www.914world.com/bbs2/index.php?sho...370541&st=0 http://www.914world.com/bbs2/index.php?act...=2&t=351248 Good luck! |
| 76-914 |
May 29 2026, 08:29 PM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,889 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
I used a scrap piece of rubber beneath the plastic bridge. (IMG:style_emoticons/default/beerchug.gif)
| hndyhrr |
May 29 2026, 08:32 PM
I used a scrap piece of rubber beneath the plastic bridge. (IMG:style_emoticons/default/beerchug.gif) I have shimmed the the bridge and that is fine now. not so much getting the expansion tank to fit. |
| 76-914 |
May 29 2026, 09:06 PM
I used a scrap piece of rubber beneath the plastic bridge. (IMG:style_emoticons/default/beerchug.gif) I have shimmed the the bridge and that is fine now. not so much getting the expansion tank to fit. My bad. I didn't take that into consideration as I 86'd the xTank with the Subaru conversion. |
| bdstone914 |
May 29 2026, 10:45 PM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,311 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Good afternoon. I have a new Dansk gas tank (installed) for the pumpkin (1970 4 cyc). Got it installed and plumbed, ready to put evap chamber (I think that what it is called, goes around filler neck.) The damn thing won't fit. Seems brackets on tank are not right! I have attached a couple of pic. Any thoughts or ideas about what to do to get it installed? Thanks Do you have the other bolt for the expansion tank installed? I have had to bend the brackets on every Dansk tank in have installed. One member had one with the filler hole off by a half inch. Loosen or remove the other enpsnsoin tank bolt. I stall a bolt on tbe end closest to the hold down strap. Try to bend it down amto align the other hole. |
Lo-Fi Version | Time is now: 30th May 2026 - 12:42 AM |
