| Quinn Moore |
May 28 2026, 04:20 PM
Qmoore ![]() ![]() Group: Members Posts: 131 Joined: 13-July 21 From: Lake Geneva, WI Member No.: 25,718 Region Association: Upper MidWest
'73 2.0 FI stock motor.
Has been running great. Until it wasn't. Idle issues, couldn't get it really dialed in. Running a little rough, idling around 1100. Not bad, but was rock solid at 950 rpm and smooth running (123 distributor) . Anyway, fast forward. Hooked up a smoke machine, found injector seal on #3 leaking. Ill replace. also noticed smoke (from the smoke machine) coming out of The butterfly valve (plate) rod ends. A tiny bit on the TPS side, and a little more on the other side. Not much, a little. Finally the question: Is that normal, serviceable, negligible? (The pictue of the TPS side, couldn't capture the smoke with my phone) Thanks for your input. QM |
May 29 2026, 06:54 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,589 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
A leak is just going to increase the idle, not cause instability. That sounds more like a sensor issue. Have you got an air fuel gauge on it?
| Quinn Moore |
May 29 2026, 10:29 AM
Lo-Fi Version | Time is now: 29th May 2026 - 11:04 AM |
