| DennisV |
May 26 2026, 08:28 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 939 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California
I'm wrestling with some final bits of the 914-6 oil tank connections. Can anyone confirm these parts and / or share photos of them installed?
Thanks for any assistance. ![]() ![]() |
May 26 2026, 08:48 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,710 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
the circlip is used to secure the rubber collar. It's the same as what the 911's use. It goes inside the rubber collar - iirc.
The thick foam collar is correct. Some people just use foam tape. It's certainly expensive for what it is. It goes on the tank before it's mounted. So it's sandwiched between the tank and the inner quarter. I'm not sure about the selling ring since I use A/N fittings but I seam to remember it's a second smaller foam washer. Could be wrong but I know there are two foam collars of different sizes. I have them in my stash if you need pics. |
| DennisV |
May 26 2026, 09:02 PM
the circlip is used to secure the rubber collar. It's the same as what the 911's use. It goes inside the rubber collar - iirc. I'm not sure about the selling ring since I use A/N fittings but I seam to remember it's a second smaller foam washer. Could be wrong but I know there are two foam collars of different sizes. I have them in my stash if you need pics. When you say "inside the rubber collar" is it the groove indicated by arrow in this photo? ![]() A photo and / or spec for the foam washer would be super helpful. Thank you! |
| Krieger |
May 26 2026, 11:14 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,857 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None
Hi Dennis,
I think I have a nos #78. Let me check. I also have something else that is suitable. That circlip in the photo goes in that groove and pushes out. Text me tomorrow if I forget. |
Lo-Fi Version | Time is now: 27th May 2026 - 02:12 AM |
