| EJP914 |
May 26 2026, 07:36 PM
Member ![]() ![]() Group: Members Posts: 288 Joined: 14-June 03 From: Monroeville, PA Member No.: 821 |
I think Brad Meuyer (sp?) told me many years ago, how to free this up.
Remove it from car. Spray huge amounts of PB Blaster or similar to the inside. Heat up the outside case of the valve with a propane torch. May take alot of heat and it will glow red, but eventually the spring inside will release. Any other ways to fix it? Thanks in advance. EJP914 |
EJP914 Stuck AAR valve '73 1.7 May 26 2026, 07:36 PM
yellowporky Yes that is a common cure for a stuck one. Unfortu... May 26 2026, 09:17 PM![]() ![]() |
Lo-Fi Version | Time is now: 27th May 2026 - 02:12 AM |
